Upper Radiator Hose Diameter
Old Jun 20, 2004 | 09:31 PM
Sohc Driver's Avatar
Default Upper Radiator Hose Diameter--B18b
Hey whats up guys, I am investing in a Greddy Water Temp Sensor Adapter..but wasn't sure which to order. They come in 30mm, 34mm, and 36mm. Do you guys have any ideas as to which one I should order? 2000 Civic EX/B18b hybrid
Thanks,
Khoi
Modified by Sohc Driver at 12:44 AM 6/21/2004
Old Jun 21, 2004 | 06:07 AM
Default Re: Upper Radiator Hose Diameter--B18b (Sohc Driver)
Bump
Old Jun 21, 2004 | 10:21 AM
bump to the tizzop
Old Jun 22, 2004 | 09:52 AM
Dan GSR's Avatar
im looking at the same greddy pieces as well, I measured the water neck coming off the head to be 32mm
which greddy piece would fit best?
Old Jun 22, 2004 | 10:49 AM
Default Re: Upper Radiator Hose Diameter--B18b (Dan GSR)
the 30 or 32mm adapter should work fine
Old Jun 22, 2004 | 12:58 PM
Dan GSR's Avatar
they don't have a 32mm
30 or 34mm
did you ever use one of these pieces?
Old Jun 22, 2004 | 01:12 PM
IN VTEC's Avatar
32mm water temp adapter
16401632
$23.24 at wiredspeed
Old Jun 22, 2004 | 03:01 PM
Dan GSR's Avatar
Default Re: Upper Radiator Hose Diameter--B18b (IN VTEC)
BlueShadow
Oct 14, 2006 02:54 PM
yellowturbo
Jun 29, 2005 05:40 AM
Sohc Driver
Jun 21, 2004 02:58 PM
Sohc Driver
Jun 21, 2004 10:20 AM
civbeater90
Aug 28, 2002 03:08 PM
