unexplainable ac problem!
Old Jun 12, 2009 | 04:05 AM
NiKKa NiKKy's Avatar
Default unexplainable ac problem!
i have a 94 gsr in a ls, my ac doesnt work, like no air comes out of any of the vents, ive checked the climate control to make sure everything is plugged in but it still isnt worrking, it just stopped blowing one day. i have no idea what to do. also is it normal for heat to be able to blow out by my feet at all times? please help!! i live in texas with no ac and only my driver side window rollls down cause theres a short somewhere for my passenger side window fuse!!
Old Jun 12, 2009 | 04:36 AM
V8 Eater's Avatar
Default Re: unexplainable ac problem!
I think having a short on the right side of the car might have a connection to your problem i.e it might have also blown you blower motor or its fuse therefore its not blowing maybe? I too had the same issue where heat was blowing at my feet but was never able to get an answer to why?
Old Jun 12, 2009 | 05:53 AM
210southstar's Avatar
Hmmm my pass widow is tha same. I think tha heat is probably comin from tha engine bay.
Old Jun 12, 2009 | 07:36 AM
FinedTuned's Avatar
Check you AC Compressor
Old Jun 12, 2009 | 11:11 AM
Naotakun 148's Avatar
You have the circulation on for your vents that's why air comes through. It's coming from the engine bay but if you just turn the circulation off it stops. I happened with my 2001 gsr then I discovered that.
As for ac. Like V8 eater stated it could be cause of the short or fuse somewhere causing the blower motor to not work. If anything I suggest taking it to the dealer ship to see why it's not working.
Old Jun 15, 2009 | 07:58 PM
yea, im sure its an electrical problem rather than my climate control or blower or comprosser going out. i've checked most of the fuses that could be controlling it but just no air blows out at all when it on the 1 2 3 or 4 lol, air started blowing from under when this plastic piece was hanging so i took it off and put it in the trunk lol a big black and white plastic shield lookin thing, i wanna take it to the dealer too but i knows its gonna be pricey for this.
Dennis1
Honda Civic (2001 - 2005)
Jul 2, 2012 07:39 AM
sohc-ek4
Mar 5, 2009 07:25 AM
dc2jdmteg05
Jul 20, 2005 12:37 PM
Token Blk Guy
Jun 10, 2003 07:43 AM
