turn off engine check light without fixing the problem?
My o2 sensor needs to be replace and I dont have the money right now to fix it. the cars obd2 and i took the sensor off(its the one connected to the cat converter).
How would I turn off the check engine light off without replacing my 02 sensor? can I just take out the light bulb?
thanks
thanks
Taking off the light bulb is one way. Actually it's the only way (if you use a scanner, the light will just come back on in 15 mins of driving).
Why not just deal with the light until you fix the sensor? It'll be a reminder for you to get it done asap.
I would consider getting a used sensor atleast. I mean you already took the time to get under there and disconnect it. A friend or a junk yard maybe?
Can't be THAT BAD with the light... I mean, think about it. You might forget that you even have a bad sensor and you'll be all lost as to why the hell your gas mileage is all crappy and ****. Yenno?
The check engine light on is another way of your car telling you how much it hates you for not taking better care of it.......
jk
jk
jk
jkTrending Topics
i just pulled the bulb when i changed clusters...if you wanna pull the bulb do it it takes no more than 5 minutes total but the fact of knowing that the CEL is there will never leave your mind so either way youre pretty much screwed
ramz7887
Dec 3, 2003 09:44 PM
