Trans help!
Old Apr 15, 2010 | 07:47 PM
02-type-s's Avatar
Default Trans help!
So I was in the Integra today, and when the light turned green, I could not get it to go into ANY gear. Not even reverse. Acting like the clutch wasnt engaged. I finally got it into 3rd and rode the clutch thru the light, then it hesitantly started going into the gears, but when its in gear, and i use the clutch, the pedal seems to shudder a little as i let off of it, then when i put it in neutral, the clutch seems fine.
WTF? Bad fluid? Bad slave cylinder? WHat do you think?
Old Apr 16, 2010 | 07:35 AM
02-type-s's Avatar
Default Re: Trans help!
bump
Old Apr 16, 2010 | 07:45 AM
WDG_729_ITR's Avatar
Did you check the fluid level? I remember in the 98 GSR I had, the clutch felt like it was going out when the fluid got a little low. I doubt your problem is the result of 'bad' fluid, but changing it out wouldn't be a bad idea. If it's not your fluid, check your slave cylinder.
http://www.team-integra.net/forum/di...g+Common+Topic
If it's not that, perhaps it is your clutch. Here is an article on clutch troubleshooting:
http://www.tpub.com/basae/93.htm
If none of these, it could be your transmission (God forbid).
roxics
Oct 5, 2015 01:11 PM
evade_07
Dec 13, 2008 10:15 PM
always smooth
Jan 25, 2008 10:19 AM
eL
23
Sep 21, 2004 03:40 PM
cecknight
Aug 26, 2004 08:12 AM
