Tranny Fluid...????
New User
Tranny Fluid...????
Hey guys, I have been going back and forth on what tranny fluid to use, and how much and such. So...what do you all use?
Re: Tranny Fluid...???? (Phat GS-R)
New User
Re: Tranny Fluid...???? (BSQ)
So...I called acura and asked what viscosity to use, and they told me they use 5w30. This is what I put in. Should I switch it out and put in Honda MTL??? Will it make THAT much of a difference? I will do it if you people feel it's necessary.
You should really use a thinner oil viscosity on the tranny. 5w-30 is an all season oil viscosity that is why most Acura dealers may recommend you use this. 10w-30 is a bit thicker. 5w-30 and Honda MTL wont really be of much difference. Wait until your next tranny oil change interval and put in some Honda MTL. It supposedly has extra additives that help in daily grind and wear.
New User
Re: Tranny Fluid...???? (jl74)
I called the best Acura service dept in my area. They know their stuff. It's the Acura Dealer that caters to the rich people in the area. However, I will do some more research. I am hoping it's fine, cuz i dont want to waste oil..
[Modified by Phat GS-R, 11:14 AM 10/23/2001]
I would recommend Honda MTL.
I also found this Q&A information on Honda MTF:
Q. Why must I use Honda brand transmission fluid in my manual transmission?
A.Like the Honda vehicles for which it's formulated, the Genuine Honda Manual Transmission Fluid (MTF) has undergone an exhaustive and exacting research and development program. When tested against competitors, it demonstrated superior lubricity in an actual Honda 5-Speed transmission. And even at -20°C, it clearly performed significantly better than leading competitors.
Genuine Honda MTF is designed for smooth engagement of the synchronizers in the transmission; this maximizes smooth gear engagement and prolongs component durability.
Always use Genuine Honda MTF. If Honda MTF is not available, you may use an API service SG, SH or SJ grade motor oil with a viscosity of SAE 10W30 or 10W40 as a temporary replacement.
However, motor oil does not contain the proper additives and continued use may cause stiffer shifting. Replace as soon as convenient.
One last thing, here is a link for changing the manual transmission fluid on a B-series Honda: http://www.hazone.com/howto/btrannyoil.htm
New User
That was an incredible post. Thank you very much. i will now go buy some tranny fluid from honda.
New User
Well...I have 5w30 in there...That is what Acura told me to use. Do you think it's fine to keep that in, because I honestly don't know. I don't want to have to have my tranny rebuilt just because i used the wrong fluid.
The tranny fluid needs only changing 30-60k miles or so, it is not even filtered, so I am GUESSING that it is not as "PICKY" as the engine on what type of oil it needs.
New User
What I don't know is wether Honda's transmissions can benefit from proper friction modifyers or not. If not, then a good synth 5w30 is fine. If it'll help, then the right viscosity + right FM will help the synchros and gears engage more smoothly. The right friction modifyers can often even help old synchros from crunching as much.
Re: Tranny Fluid...???? (alic888)
Redline MTL, nothing else
Redline Oil Dealers:
http://www.redlineoil.com/dealers.htm
[Modified by Shmeek, 8:18 AM 10/24/2001]
New User
Oh yeah, I am on my way to get Honda MTF in about an hour or so. I don't want to chance it. Shifting doesn't seem smooth with what I have right now either..
bk7794
06-22-2011 05:11 PM
Historyg
10-01-2007 10:11 PM
