Traction problems !!!
Old Dec 16, 2003 | 06:37 AM
MikeTV
Guest
Posts: n/a
Default Traction problems !!!
Hey guys how the hell have you all been ?
Anyway so I've started having a problem that I figured you guys could give some insight on. This past summer, I found that my perfect launch was achieved at 4500 rpm ( the tires would just screech slighty and I was off). But for the past few weeks, when I launch at 4500 rpm, I just sit at the line spinning !
Now there could be a few things at play here. First, I have Azenis, that I have used quite a bit since the summer, but upon visual inspection, they seem to be fine with almost the same tread amount as what I had in the summer. The second thing I was thinking is that could it be the change in the temperature ? The temp has drop recently by about 30 degrees. I mean would the sudden drop in temp give the motor that much extra power, that I am spinning where I once was catching traction ? Or could it be something else? What do you guys think ?
Old Dec 16, 2003 | 06:54 AM
NewbyforIntegs's Avatar
Either youve used your tires too its full extent and need replacing, or its what you said. The temperature has to do with everything when it comes to better traction and off the line accleration. At the drag, people burn out/spin tires to heat them up a lil bit. Alot of people cut off .1-.3 due to temperature. if its moist, dry, humid, hot cold, everything comes into effect. So I think its just temperature change man, no worries
Old Dec 16, 2003 | 07:13 AM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: (NewbyforIntegs)
Last time I was at the track I was spinning into thrid so I am almost positive the weather is affecting your tires traction.
Your Epitaph.'s Avatar
///M Power
i think it would be a combination of everything u said...if u drove on the tires, then theyre going to wear, even if your not dragging or racing on them. the thing with the temp is: ur not really making any more power per se, even though ur engine is sucking in a colder intake charge. but, ur tires are probably not warm enough to grip the asphalt when u launch. thats my best guess.
Old Dec 16, 2003 | 07:24 AM
RedTegLS's Avatar
Default Re: (J_D_M_9_4)
fast car+cold roads=no traction. That is my math lesson for today. There will be a pop quiz later!
Old Dec 16, 2003 | 08:24 AM
MikeTV
Guest
Posts: n/a
drove on the tires, then theyre going to wear, even if your not dragging or racing on them. the thing with the temp is: ur not really making any more power per se, even though ur engine is sucking in a colder intake charge. but, ur tires are probably not warm enough to grip the asphalt when u launch. thats my best guess.[/QUOTE]
Good point...I actually never thought of that
Old Dec 16, 2003 | 09:23 AM
jdm_lover's Avatar
Default Re: (Eclipse spanker)
no worries ..i feel your pain!
its temperture and humidity and its cold now days...so things start to get pretty cold and easy to slip...even when its dry pavement ...its wintertime...
Old Dec 17, 2003 | 07:13 PM
luvinmyGSR's Avatar
Default Re: (jdm_lover)
yeah the colder it is the more u spin
Old Dec 18, 2003 | 12:34 PM
gsr2jdm's Avatar
Default Re: (luvinmyGSR)
L.S.D.
Old Dec 19, 2003 | 12:01 AM
Nathan1234's Avatar
Cold tires=hard rubber=bad traction.
Old Dec 19, 2003 | 06:23 AM
MooreBoost's Avatar
Default Re: (Nathan1234)
Is this at the same track? Generally, tires get stickier as they get older. So if its at the same track, Ill stick with everyone else saying that the temp is whats killing your traction.
gmoore
Old Dec 19, 2003 | 07:32 AM
XtremeCarTuner's Avatar
Default Re: (gsr2jdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr2jdm &raquo;</TD></TR><TR><TD CLASS="quote"> L.S.D. </TD></TR></TABLE> very good suggestion. Totally agree on that one. That'll make a huge difference when you launch.
climb_on
12
May 19, 2008 08:10 PM
IntegraBoy04
Aug 29, 2003 01:49 PM
piotrush
Mar 14, 2003 08:04 AM
xchosun1x
Jan 18, 2003 08:15 PM
TypeR Chris
Sep 1, 2002 02:11 AM
