Tiny clutch removal problem, need help.
Old Mar 2, 2003 | 07:26 PM
dc2pffsssttt's Avatar
Default Tiny clutch removal problem, need help.
Im replacing my clutch for my turbo setup. I have all the bolts out and everything, but the trans does not seem to completely pull away from the block. Do i have to remove the clutch dust shield to get this thing off. any suggestions?
Old Mar 2, 2003 | 08:08 PM
tilt's Avatar
Default Re: Tiny clutch removal problem, need help. (dc2pffsssttt)
the flywheel cover? If I remember correctly, I had to take it off.
http://www.c-speedracing.com/howto/b...tch/clutch.php
Old Mar 2, 2003 | 08:13 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Tiny clutch removal problem, need help. (tilt)
Yes, you'll need to take the flywheel cover off. Also check in that same area, there is one bolt that's screwed into the direction of the passenger wheel. All the other bolts are going the other direction, so maybe you missed that one.
You'll also need to take off the bolts of the rear mount.
After all that, just shake the damn thing HARD. Maybe a pry bar will help too. Sometimes they're really stuck on there. Good luck.
Mushroom picker
Honda CR-V & Element
Aug 13, 2019 07:28 AM
snatch
16
Aug 11, 2004 08:16 PM
civcexcoupeblack
Mar 19, 2003 09:22 PM
integraautox
Jan 23, 2003 01:14 PM
lsvtec101
Oct 19, 2002 02:17 AM
