timing gun
Old Mar 10, 2003 | 06:04 PM
turbospool's Avatar
Default timing gun
sorry for the newb question, but how do you check and adjust your timing with a timing light? can someone explain in detail please? thanks
please include which marks on the crank pulley etc.
Old Mar 10, 2003 | 06:19 PM
thrty8street's Avatar
Default Re: timing gun (turbospool)
Where can i buy one? how much are they going for??
Old Mar 11, 2003 | 04:15 AM
JimBlake's Avatar
I got my timing light at Sears for about $35 a long time ago...
You hook it to the battery for power, then you clamp a pickup around the #1 spark plug wire, then start the engine. Shine the light at the crank pulley & look for the marks to line up.
Depending on what year or whatever; before you start the engine, jumper a connector under your dashboard to tell the computer not to mess with the timing while you're measuring it. The marks on the crank pulley and the pointer on the timing cover which they're supposed to line up with probably change a little from year to year. Check your repair manual.
To adjust it you loosen the distributor mounting bolts, & twist the distributor a little bit till the timing marks line up the way you want.
[Modified by JimBlake, 8:16 AM 3/11/2003]
Old Mar 11, 2003 | 09:13 AM
ejprimo's Avatar
Default Re: timing gun (JimBlake)
also, turning the distributor toward the firewall advances the timing and turning it away from the firewall retards timing.
Old Mar 11, 2003 | 09:27 AM
GreenEggs248's Avatar
Default Re: timing gun (ejprimo)
Here's a good link:
http://www.c-speedracing.com/howto/timing/timing.php
Old Mar 11, 2003 | 12:50 PM
turbospool's Avatar
Default Re: timing gun (GreenEggs248)
thanks, but how do i know how much timing im advancing or retarding?
Old Mar 11, 2003 | 06:49 PM
KoRE's Avatar
by the marks on the crank pulley
the group of 3 the one that's alone is 0
the one closest to the firewall is 14 the middle one is 16 and the farthest is 18
there are timing light where you can adjust it to a certain number using a dial thoguh.
90civic-ZC
Nov 23, 2011 02:36 PM
LoseRPunKx182
Aug 6, 2005 09:36 PM
Creepin4DR
Dec 10, 2004 07:57 PM
wantmorepower
Apr 16, 2003 09:52 PM
civbeater90
Nov 16, 2002 12:46 PM
