throwing cel code 43. what is it? help
im throwing a CEL code 43 on my 94 Acura Integra LS but i have no check engine light.. only sometimes at night, and it goes away after i warm up my car and turn off / on my car again.. please help
Guest
Posts: n/a
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JesDM »</TD></TR><TR><TD CLASS="quote">"43 Fuel supply system "
wtf is that??</TD></TR></TABLE>
that is the system that supplies the fuel to your car. are you having problems with it other than the CEL? or does it seem to be running fine?
the more details the easier it is for people to help you.
Fuel Supply or o2 Sensor.
I had code 43 on my Accord, turns out i needed an o2 sensor.
It would only come up after i drove the car for a while.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by so.dark.the.con.of.man »</TD></TR><TR><TD CLASS="quote">that is the system that supplies the fuel to your car. are you having problems with it other than the CEL? or does it seem to be running fine?
the more details the easier it is for people to help you. </TD></TR></TABLE>
more details : never had check engine light ON when first turn on car, only after i drive it around when its COLD (not fully warmed up) and then it turns on, and i turn off my car, turn it back on, and its gone. so code 43 most likely means my o2 sensor going bad??
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JesDM »</TD></TR><TR><TD CLASS="quote">more details : never had check engine light ON when first turn on car, only after i drive it around when its COLD (not fully warmed up) and then it turns on, and i turn off my car, turn it back on, and its gone. so code 43 most likely means my o2 sensor going bad??</TD></TR></TABLE>
sounds like it is probably the o2 sensor same thing happens with my friends nissan.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by so.dark.the.con.of.man »</TD></TR><TR><TD CLASS="quote">sounds like it is probably the o2 sensor same thing happens with my friends nissan. </TD></TR></TABLE>
so right now its thorwing this CEL 43, but no check engine light, will it affect anything with performance as of right now ??
It will affect your gas milage alot.
It can also damage your Cat.
Those are expensive to replace.
Im sure there are more things you can damage by running too rich.
Go to Autozone and get a Bosh o2 sensor for $55.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slo Cord »</TD></TR><TR><TD CLASS="quote">It will affect your gas milage alot.
Go to Autozone and get a Bosh o2 sensor for $55.</TD></TR></TABLE>
im runnin /w a straight pipe so no Cat. i know my gas milage has been taking a hit, but i mean performance wise.. any loss in HP? there is no CHECK ENGINE light, but iKNOW im seeing my CEL flash when i check for CEL witht he paperclip.. the only time check engine light comes on is when i run it forawhile, it comes on, then i turn off car and turn back on, and it goes away.. AM I LOSING ANY PERFORMANCE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slo Cord »</TD></TR><TR><TD CLASS="quote">Yes you are hurting your performance...</TD></TR></TABLE>
even if i have no check engine light?? wow how much performance r we talkin about??
from the set-up i saw on your cardomain site for it being a mild set-up i dont see you losing a whole lot of power but get that sensor installed re-set the ecu and with gas prices the way they are it will pay for itself quickly. oh ya BTW mad props on the rear lip (i have the same one) GL with the prob.
vtecludeh22
Dec 3, 2004 12:03 PM
