Threw a code.....Please help!
Old Oct 12, 2002 | 11:00 AM
MooreBoost's Avatar
Default Threw a code.....Please help!
Allright, I just got back from my car store after having a throttle rotor installed. Seemed to be ok. So I floor it in second. Car runs fine, check engine light comes on. WTF? The Maintenace required light has been flickering when I start it up for the past two days, after I had my ignition done. I didnt think anynthing of it because I thought it would stay light if it was for real. So what do you think is up? Check sig for setup, and the Acura dealer won't be open until Mon. Thanks,
gmoore
Old Oct 12, 2002 | 03:48 PM
VaporTrail's Avatar
New User
Default Re: Threw a code.....Please help! (gmoore379)
jump the ECU, check the code. My guess says throttle position sensor is out of adjustment.
Old Oct 12, 2002 | 04:48 PM
MooreBoost's Avatar
Default Re: Threw a code.....Please help! (VaporTrail)
bump ...never done this before. Hostboard guys say open up the ecu box, look for green wire with two hole connector thingy, then short that connection. Then turn the car on , but dont start it, watch for how many long and short blinks of the check engine light. Will this harm the ecu?
gmoore
Old Oct 12, 2002 | 08:14 PM
TRENDSETTLER's Avatar
wont harm the ecu...on the passenger side under the dash there will be a green rubber thing with a blue plug in it...pull out the blue plug and use a paper clip to connect the two holes...turn the egnition to "on" and count the flashes...i doubt i explained this right so you can check http://www.c-speedracing.com/faq/06.html it has pics and better instructions
Old Oct 12, 2002 | 08:23 PM
piatl7il77's Avatar
that maintenance light just means youneed to like change the oil i think but, i do know that you can reset that by holding the button under your dash. under the steering column. there is a box just off to the right. hold that button untill the maintenance light disapears.
88crx Osaka
Aug 20, 2011 10:42 PM
Atreyu57
May 16, 2006 12:19 PM
KillaBk
Oct 29, 2005 06:00 PM
EVIL TYPE R
Feb 21, 2005 02:31 PM
af97civic
Mar 28, 2003 08:50 PM
