things needed for adding a supercharger
Old Sep 22, 2001 | 05:25 PM
sicilian2k1's Avatar
New User
Default things needed for adding a supercharger
you have to run low compression to run a supercharger or turbo right? also, what other changes will you have to make to the cam? i have heard type r cams will not work right?
Old Sep 22, 2001 | 05:34 PM
slowerthanu's Avatar
New User
Default Re: things needed for adding a supercharger (sicilian2k1)
Too tun a S/C you need 1 thing, a trash can, Grab JRSC'er, open trash can, throw JRSC in Trash can.
Old Sep 22, 2001 | 08:16 PM
GS Type R's Avatar
New User
either he has never owned 1 or did and his car wasnt tuned right but on either account he awnsered neither ?
anyway,
stock internals should be ok as long as you dont get a boost controller
but i would at the very least upgrade your fuel delivery system, ie. pump, fuelrail,
injectors and make sure you run colder sparkplugs because of the increase in heat and combustion, also make sure you have your car properly tuned by someone that knows how to tune a supercharger
Old Sep 22, 2001 | 08:29 PM
New User
Default Re: things needed for adding a supercharger (GS Type R)
anyway,
No, I have not owned 1 and yes I have had ALOT of experiance with JRSC's. Too much bad to overide any of the few positive attributes of that crappy system.
Old Sep 22, 2001 | 10:37 PM
Rory Breaker's Avatar
Blah blah
To answer the question in the post (the topic makes more sense than the body ), for a JRSC install you need:
JRSC
JR FMU or Cartech/Vortech/Something
Intake Manifold Gasket, maybe TB gasket
High flow fuel pump (Walbro GSS317, 342, whatever)
Extra Clamps
Underhood or In-Cabin FP Guage/Boost/AF guage
New fuel filter (if yours is over 15k)
NGK BKR7E plugs
Lotsa Lotsa tools
MOST importantly, a lot of patience and time.
ITR cams would be fine. Traditionally, using aggressive cams with an SC isnt the brightest idea, but since theyre still pretty mild youd see gains.
Old Sep 22, 2001 | 11:18 PM
H23 Power's Avatar
Default Re: things needed for adding a supercharger (newgsrdriver)
gsr cams would be better than the type r cams with a supercharger
Old Sep 22, 2001 | 11:21 PM
Default Re: things needed for adding a supercharger (01GSR)
A more aggressive cam would mean youre more likely to detonate, as I understand it. As long as you can run the same setup as the GSR cams(timing, fuel, etc) without detonation, I dont see how you would not benefit.
FearTheH
Apr 13, 2009 09:46 AM
924doorEG
Apr 28, 2008 10:25 PM
escape2me
Sep 30, 2005 07:29 AM
mrx
Aug 25, 2004 11:51 AM
fredtoast
Dec 3, 2002 12:56 PM
