is there a difference?
Old May 13, 2008 | 08:58 AM
P'cola GSR's Avatar
Default is there a difference?
i have a gsr with 01 type-r head and was wonderin if theres a difference in the gap on spark plugs cause i need to change mine.
thankx
Old May 13, 2008 | 01:05 PM
I AM WEASEL's Avatar
Default Re: is there a difference? (P'cola GSR)
yes they are gapped differently
itr gapped to .044
gsr gapped to .052
ITR Spark Plugs (NGK)
GSR Spark Plugs (NGK)
Old May 13, 2008 | 07:50 PM
P'cola GSR's Avatar
Default Re: is there a difference? (-DC4-)
thank you for that, would it matter which gap on my setup?
Old May 13, 2008 | 07:58 PM
all-mtr-teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P’cola GSR &raquo;</TD></TR><TR><TD CLASS="quote">thank you for that, would it matter which gap on my setup?</TD></TR></TABLE>
Uh, yeah, heat ranges are different also.
Old May 15, 2008 | 04:06 PM
P'cola GSR's Avatar
Default Re: is there a difference? (all-mtr-teg)
then what you would recomend?
Old May 15, 2008 | 04:25 PM
NGK (7-heat range) gapped to .044" or 1.1mm if your running close to ITR compression.
If stock GSR compression or lower since you're running an ITR head, NGK (6-heat range gapped to .052" or 1.3mm
Old May 15, 2008 | 04:34 PM
P'cola GSR's Avatar
thank you, i've been asking everyone this and you actually gave me an ansewer. its still on gsr compression.
Old May 15, 2008 | 04:45 PM
If block is stock, head hasn't been milled, and ITR head with stock valves, your CR is close to 9.8:1
http://www.zealautowerks.com
Old May 15, 2008 | 04:56 PM
P'cola GSR's Avatar
i think thats what the numbers were last time i checked
DC4R27
Jun 2, 2009 05:11 AM
peacexisxfree
Oct 31, 2005 07:13 AM
hybrid_vtec
Aug 20, 2004 05:42 AM
4door-r
Feb 29, 2004 01:10 PM
sublimnal
Jun 4, 2003 08:36 PM
