Testing-Replacing Injectors 95 LS
Old Dec 22, 2001 | 02:18 PM
ManinCamo's Avatar
New User
Default Testing-Replacing Injectors 95 LS
How difficult is it to test and or replace the fuel injectors in a 95 LS? #4 spark plug gets spark, but when the wire is pulled off the plug, there is no difference in idle RPM, #4 chamber is dead. I suspect the injector is bad because of the above tests. Ihave the haynes/chiltons i don't remember, and it looks pretty straight forward, but i wanted some comment from you guys.
Old Dec 22, 2001 | 03:28 PM
Tweakmeister's Avatar
Default Re: Testing-Replacing Injectors 95 LS (ManinCamo)
It's not too hard. You just have to unbolt the fuel rail and take a few other screws off. The hardest part is probably draining the fuel!
I estimate maybe 2-4 hours (very conservatively).
Old Dec 22, 2001 | 06:01 PM
OneThirtyEight's Avatar
Default Re: Testing-Replacing Injectors 95 LS (Tweakmeister)
easy as ****.
Project_DX
Oct 17, 2006 09:32 AM
civicguy81
May 23, 2006 03:33 PM
rohec04
Sep 22, 2005 01:54 PM
ratherbewalking
Jan 1, 2003 07:46 PM
b16awarrior
28
Sep 20, 2002 05:26 PM
