Temperature guage problem. PLEASE HELP!!
Old Dec 27, 2004 | 09:54 PM
LowAcura's Avatar
Default Temperature guage problem. PLEASE HELP!!
Earlier in the year (Jan) my temp guage would move back and forth a tiny bit as if its circulating the cold and hot water and reading it that way.. and when the car got to normal temperatures it would work normal...
NOW it just stopped working and when i turn off the car and turn it back on it works sometimes or while i drive it would just leap to where it should be at or die when its actually working. Most of the time it doesnt work though. This just happened.
Can anyone tell me what it could be? Bad guage? or a problem somewhere else? I have never touched the needle and ive owned the car for a while...
thanks
*EDIT* Its a 99 GSR about to hit 100,000 miles
Old Dec 28, 2004 | 03:16 AM
Calsonic's Avatar
Sounds like you might need a new thermostat but it could also be a faulty gauge or a bad ground wire. You should check under the distributor where the connector is.
Old Dec 29, 2004 | 10:37 PM
LowAcura's Avatar
Default Re: (Calsonic)
thanks!
It works now! The ground was holding with a strand of wire; I fixed it... thanks again for the help
Modified by LowAcura at 8:46 AM 12/30/2004
Old Dec 30, 2004 | 12:12 PM
Calsonic's Avatar
Glad to help.
blasterman87
Aug 11, 2009 01:49 PM
RICE POLICE SIP
Dec 1, 2005 11:09 PM
JunkyardDog
Nov 28, 2005 11:02 AM
nominous
May 23, 2005 01:30 AM
vtec69
25
Nov 29, 2004 01:01 PM
