Temp Guage
Old Jun 20, 2004 | 08:36 AM
dashway's Avatar
Default Temp Guage not working
not workingthe temp gauge doesnt work after swapping the clutch...thought i had crossed the connection with the Reverse wire from the trans as theyre both yellow so i switched em...the temp goes straight to hot when i make reverse so i know its not that ..theyre no codes the fans even come on after a while .
any suggestions???
91 XSI
Modified by dashway at 7:03 PM 6/20/2004
Old Jun 20, 2004 | 04:26 PM
teg92's Avatar
Default Re: Temp Guage not working (dashway)
ECT is a thermistor, resistance drops as temperature increases. If your temp is always at full hot, sounds like you've got a short to ground somewhere from the wire at the connector to the ECU. Good luck.
SeraphimKidd
11
Aug 26, 2009 08:55 PM
crxkid24
Sep 21, 2007 07:39 PM
VTECR021
Apr 22, 2004 08:04 PM
1.8EG-T
Nov 10, 2001 04:45 PM
