Tach Jumping???
Old Jan 21, 2008 | 03:31 PM
pacman_dc2's Avatar
Default Tach Jumping???
I have a gsr and the cluster jumps alot, i noticed when its cold and im cruising it will just jump by itself, like crazy, i already changed dizzy cap rotor and took wires off the clip and put them direct, it helped for about a week or two and it started jumping again, i hate it cuz i use my mph to shift lol sometimes it will go smoothly and just jump a lil bit but other times its crazy... anyone know wut will cause this ??? or experienced this before ??
Old Jan 21, 2008 | 04:08 PM
Micha's Avatar
FAILWGN
Default Re: Tach Jumping??? (pacman_dc2)
Try your vehicle speed sensor that is located on the top of your transmission.
Old Jan 21, 2008 | 04:29 PM
pacman_dc2's Avatar
Default Re: Tach Jumping??? (micha)
if im not mistaken if its the speed sensor, won't the mph not work not the tach ??
Old Jan 21, 2008 | 04:47 PM
red integra lsr's Avatar
I had same prob and when i changed distributor it stoped. coud also be a bad cluster
Old Jan 21, 2008 | 05:26 PM
TB123's Avatar
This happened to my gsr too. I tightened the wires going into the ignition control module with a pair of pliers and that fixed it. If you have not already checked the ignition control module, it might be a good idea.
Old Jan 21, 2008 | 06:06 PM
pacman_dc2's Avatar
Default Re: Tach Jumping??? (TB123)
if im not mistaken that is in the dizzy correct ??
Old Jan 21, 2008 | 06:35 PM
hondadude_rudo's Avatar
i have seen this problem 4 times before on friends cars. 2 of them had the dizzy go out shortly after it occurred, while the other two just lost some performance. most likely your problem is in the dizzy, but it could also be a short somewhere in your wirng. good luck on solving your problem.
Old Jan 21, 2008 | 08:02 PM
jdm98teg94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TB123 &raquo;</TD></TR><TR><TD CLASS="quote">This happened to my gsr too. I tightened the wires going into the ignition control module with a pair of pliers and that fixed it. If you have not already checked the ignition control module, it might be a good idea. </TD></TR></TABLE>
same thing happend to me right after doing my swap and tried most of the things that people have said already and nothing worked so i took it to a friend and he suggested the same thing so i tighted the ignition control modual wires and it fixed it too.
Old Jan 22, 2008 | 06:21 AM
TB123's Avatar
Yes, it is in the distributor. If tightening the wires does not work, you might need to replace the ignition control module. From what I have heard, this is the most common reason for the tach to be jumping. You might also want to check all of your grounds.
Old Jan 22, 2008 | 04:42 PM
pacman_dc2's Avatar
well ima try doin that today thanks for help from all
Drola
Sep 14, 2011 07:26 AM
slammedNslowLS
Jul 8, 2009 02:23 PM
LilJohn198807
Dec 10, 2008 06:03 PM
crxh22project
13
May 14, 2005 02:03 PM
JiVe
19
Jul 22, 2003 01:12 PM
