syncro going bad
Old Sep 22, 2005 | 09:11 PM
Devo94ac's Avatar
Default syncro going bad
I have a bad syncro when i shift from 2 into 3. Can someone help me?
Old Sep 23, 2005 | 03:39 PM
Sam92Teg's Avatar
Default Re: syncro going bad (Devo94ac)
First make sure your clutch engagement point is adjusted properly.
Then check your Manual Tranny Fluids condition/level, better yet, swap some fresh Honda MTF in and see if your grinds go away. If not, then either learn to time your shifts better to prevent grindage, or replace syncro / tranny.
Some people also think Pennzoil friction modified syncromesh MTF will solve some grinding issues, but I have only used Honda MTF and have no problems at all with my high mileage tranny.
Old Sep 23, 2005 | 03:43 PM
mattcivic's Avatar
Default Re: syncro going bad (Sam92Teg)
ya try what he said my tranny would fall out of 5th it was due to low fluid but pulled tranny anyways changed all the syncros bearings seals and added lsd for 1,000 bucks worth every penny
ITRICED
Nov 9, 2009 07:39 PM
Cookiegsr
11
Sep 5, 2009 09:08 PM
Gkdc182
Transmission & Drivetrain
Jan 27, 2009 10:24 PM
daniel990836
Oct 7, 2007 02:53 PM
ill phil
15
Sep 4, 2002 10:37 PM
