Symptoms of a bad fan relay and a bad thermo. fan switch?
Ok, so im back. I took a wire and bridged the two connections on the thermo. fan switch, and the fan sensor. When I bridged the wire on the thermo. fan switch the fans came on, and when I bridged the wires on the fan sensor the fans didnt come on, so Im guessing its the relay and the ther. fan switch are the problems? Thanks.
Re: Symptoms of a bad fan relay and a bad thermo. fan switch? (motormike40)
If you jumped the connector at the fan switch, and the fan came on, then your relay is fine. You need a new fan switch.
What's a fan sensor?
Im thread HIjacking since he solved his problem::::::::
Are both FANS supposed to come on when I turn on the AC?
I had the notion that one fan turns on and then the other one when the temp increased.
My problem is that they both turn on together regardless.
Suggestions?
Suggestions?
littleblue
10-14-2008 04:44 AM
kai-chun
12
09-08-2006 03:20 PM
