Swapping in Integra
Old Jul 27, 2003 | 04:50 PM
crxsirvtec's Avatar
Default Swapping in Integra
hey..
i want to know what the best engine in a 90 Integra to swap... i have a GS model..
Also auto tranny, going to convert to 5 spd...
JDM GSR is the best??
Thanks guys in advance...
Old Jul 27, 2003 | 04:55 PM
thaiphob's Avatar
Nikon!!!
Default Re: Swapping in Integra (crxsirvtec)
just depends on what your looking to do with your car.....
Old Jul 27, 2003 | 05:12 PM
RayB's Avatar
It depends on what you consider best. If you are looking from a monetary standpoint, no. If money is no object and all you want is power then, yes. Atleast, if you're talking strictly engine swap...
The B18C will require a conversion harness. It also comes with a hydro tranny. All manual DA's came with cable trannies. The best and easiest route to the tranny conversion will be a 1st gen B16 tranny (cable tranny) because you will be able to find parts that will directly fit your DA for it.
If you have a good bit of money to spend then you might want to consider turboing a 1st gen B16 or using your old LS block for an LSVTEC...there is a lot of great info on this site and a site called G2IC.com (specifically for DA's)...when you get some time, run the search function on this site and G2IC and read up...be careful, there is a lot of misinformation but if you read carefully you'll be able to pick it all out...have fun, I hope that I've been some help....
dc4ok
May 25, 2011 07:36 PM
dbn
11
Aug 9, 2006 04:36 PM
CRX-SIR
Jul 27, 2005 03:43 AM
9200RPM
Dec 2, 2003 01:18 PM
xxplosif1
Aug 7, 2002 07:12 AM
