Surging Idle
Old Nov 29, 2008 | 10:35 AM
AccordSleeperZzZ's Avatar
Default Surging Idle
howdy fellas,
Got a 93 DA with a b18a1 in it. one day this fall the idle started to surge from normal(~800) to 2500rpm. and it does this continuously whenever it is out of gear. i tried changing the IACV, but no change.
do you think it might be the FITV?
i figure if it was a vacuum leak, the idle would just be high, not surging the way that it has been doing.
any ideas/input would be greatly appreciated.
and pictures get views, so here's the teg.
thanks a bunch!
-Chris
Old Nov 29, 2008 | 12:55 PM
efvader's Avatar
most likely your idle air control valve, or maybe fast idle valve. did you use a new iacv?
Old Dec 8, 2008 | 07:21 PM
matt736's Avatar
remove the intake and put your hand over the throttle body if it DOES NOT choke out its a vac leak.
da9crxsi
Jun 4, 2012 09:52 AM
Marble
Nov 18, 2004 05:51 AM
dannylDAsport
Mar 28, 2004 11:38 PM
killa_lude
Aug 16, 2003 08:33 AM
