Subframe tear out help
Old Jun 26, 2001 | 12:34 AM
Integraphile's Avatar
Default Subframe tear out help
I had a subframe tear out where the nuts were pulled through. Now, the bottom tearout is the size of a nickel, but the top is more of a jagged shape. I'm planning to use the Beaks kit and I'm wondering whether first, I should reinforce the subframe and second, how to do it.
I tried fitting the nut plate (the one that goes in the back) and it covers the hole adequately, although with less area to bear the load, I fear that I could have another tear out. Anyone have any ideas how to reinforce the subframe? I'm just thinking a piece of steel, but I'm open to any other suggestions......... TIA
Old Jun 26, 2001 | 04:13 AM
VTechie's Avatar
Default Re: Subframe tear out help (Integraphile)
Sorry to hear it, dude.
Your only real solution here is to do some welding. That jagged upper hole especially is just going to get worse (jagged tears tend to promote crack growth). You'll have to:
1. Cut or drill out the remaining material to make it a round hole, or at least so there are no sharp corners.
2. MIG weld some steel to repair the holes. New bolt holes for the suspension mounts can be drilled into the new material. Or, if you were getting fancy, make up some steel plate with pre-drilled holes to weld onto the area.
3. Make sure you heat-treat and paint the repair job.
I know this sounds time-consuming, but I think it's your only course. There are probably a bunch of welding shops in your area that would be willing to do this.
Old Jun 26, 2001 | 04:59 AM
MechE00's Avatar
take it to a body/collision repair shop if you don't want to deal with the hassle..
Old Jun 26, 2001 | 05:06 AM
VTechie's Avatar
Default Re: Subframe tear out help (MechE00)
Yeah, sure, take the easy way out.
Old Jun 26, 2001 | 09:01 AM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Subframe tear out help (VTechie)
If you are in the SF Bay Area, I know a guy that'll weld/reinforce it for about $250. He did mine a year ago and it is holding up very well. I've been to the road course twice and hard cornering on the streets with no signs of problems at all.
I had torn out the Skunkworks 21mm sway bar.
Old Jun 26, 2001 | 05:08 PM
Default Re: Subframe tear out help (Gee3)
Thanks for the suggestion.
Gee3 - How was yours reinforced? In particular, I'm looking for specific examples. I haven't seen nor read any posts on reinforcements on subframe tear outs. $200 is just about the most that I would spend, so I'm relying mostly on what I could do first. Thanks.
Old Jun 26, 2001 | 10:13 PM
Gee3's Avatar
Integraphile - Mine tore where the brackets are mounted. They didn't tear out the bolt holes. Instead they tore around the sway bar brackets, tearing out like a squarish or rectangular shape. So the guy welded the subframe at the tears and then welded a larger ,but thin, piece of steel over that and drilled holes into the sheet metal where the bracket holes are. I wish i had pics but I wasn't there when he did the work. The extra metal helped to strenghten that area and I have had no probs with it so far. He tried to weld a thicker piece of steel but it was too thick for the bolts or something like that. I forgot his explanation. He also painted the area to protect it from rusting and to hide it from plain view. Mostly to make it look nice.
hope this helped to answer your question! Good luck!
maxogsr
Welding / Fabrication
Aug 10, 2011 06:56 AM
tree fingers
12
Sep 19, 2008 04:18 PM
DOHC Kid
Jun 8, 2008 05:55 PM
foz
21
Jun 13, 2005 04:47 PM
