stripped block
the drivers side holes in the block where the motor mount attach are stripped does anybody have experience with this i need help do i need to pull the motor or can i just use an engine hoist to hold it and retap the holes
i had an engine built once and when they shipped it back to me the part of the block your talking about cracked off on one of the holes. i ended up having to drill the holes out bigger and tap them with a bigger size to make everything work. drilling through the cast block mount was a BITCH tho.
You can raise and support the block from underneith with a jack and a big block of wood. I did this myself and was able to tap and repair all 3 bolt holes for the driver side motor mount.
stickyfingers
13
Feb 8, 2005 04:50 PM
