Steering Rack Adjustment Tool - 40mm wrench needed
Old 04-19-2019, 07:17 AM
zeroptzero's Avatar
Default Steering Rack Adjustment Tool - 40mm wrench needed
The steering rack on my 2000 GS-R is out of whack, the steering assist is crazy high at highway speeds and I don't like it at all. The integra steering is variable assist, so it should be high at low speeds and less at higher speeds. Mine works fine at low speeds but the assist increases dramatically at higher speeds and is way too senstitive to inputs.
It seems like the fix is to adjust the steering rack which requires a 40mm wrench from Honda. I am wondering if I can do it with a normal 40mm box end wrench (spanner) / combination wrench as I could likely source one from tool shop. The Honda tool is not available in my parts. Has anyone accomplished this adjustment without the Honda tool ? Thanks for any replies.
Old 04-19-2019, 06:43 PM
MotorMouth93's Avatar
Default Re: Steering Rack Adjustment Tool - 40mm wrench needed
You can loosen/tighten the 40mm nut fairly easily with a hammer and chisel. However, 99 times out of 100, the rack adjustment is not the problem.
Old 04-19-2019, 06:46 PM
zeroptzero's Avatar
Thanks for the reply, I never thought about a hammer and chisel but I have those in my possession. I heard of some members fixing their steering assist issues with a rack adjustment so I hope to try that first - free.
Old 04-21-2019, 04:26 PM
tamboo's Avatar
i sent mine to White_EG1 when i was done with it.
maybe he has it or can remember who he sent it to next.
Old 04-21-2019, 04:58 PM
-Intl Steve Krew
Caoboy's Avatar
@White_EG1
Old 04-21-2019, 05:12 PM
zeroptzero's Avatar
Thanks for the replies and added contact info ^
Old 04-22-2019, 10:04 AM
GR_DC2's Avatar
IIRC, a normal adjustable wrench will not easily fit in the tight space (assuming you are doing it with the rack installed).
Old 04-22-2019, 01:29 PM
zeroptzero's Avatar
Thanks for the reply, I was wondering about the fitment issue, but it isn't that much larger than the Honda tool, though I could be wrong. I may need to get under there and take off the cover plate to know for sure.
Old 04-22-2019, 02:16 PM
stin1's Avatar
Is the tool discontinued? Pardon my ignorance, I don't know what myparts is.
Old 04-22-2019, 08:15 PM
dc2iggy's Avatar
You can still buy it. Part # 07AAA-TL2A100
$21 here https://www.acurapartswarehouse.com/...a-tl2a100.html
Old 04-23-2019, 03:15 AM
zeroptzero's Avatar
Thanks for the link , much appreciated.
Old 04-25-2019, 04:31 AM
White_EG1's Avatar
Since tamboo sent me the tool I’ve had over 9 builds happen in my garage. I’ve accumulated a **** ton of parts and tools, I’ll look around for it, I’m sure it has to be somewhere.
I did Inner tie rods with the tool, but I didn’t know you could use it to adjust the rack too.
Old 04-25-2019, 10:35 AM
dc2iggy's Avatar
You bet. Please update thread if the adjustment worked.
DREW410
Suspension & Brakes
10-19-2017 10:06 AM
Jaynik
01-04-2010 08:23 PM
jr_istheman
04-30-2009 10:01 AM
krayjeegsr
08-15-2006 09:42 PM
an2ny888
05-27-2005 05:06 AM
Quick Reply: Steering Rack Adjustment Tool - 40mm wrench needed
