Steering Column Bolt Question: Help!
Old Apr 25, 2008 | 05:05 PM
B18C1NMotion's Avatar
Default Steering Column...WTF!?
so one day i noticed one of my bolts was missing from my steering column where it bolts into the steering rack. i went to the dealership and bought two brand new bolts. i went to put in the other bolt and the column has shifted the other direction and its a BITCH to line up the holes to drop the bolts in. i've spent countless hours and i've had sslbn8o (nate) try and help me to see if it would be easier with two people...nope. this is by far one of the trickest things to do without pulling the motor or replacing the whole steering column. ANY IDEAS???
at this point, i'm dumbfounded and its becoming annoying. i want to figure this out before i start breaking more **** on my car out of frustration. any help/input is appreciated.
THANKS!
Old Apr 25, 2008 | 08:32 PM
crv-techu's Avatar
Default Re: Steering Column...WTF!? (B18C1NMotion)
There should be 2 bolts.take them both loose and the yoke will slide up and down on the shaft.
Old Apr 26, 2008 | 08:13 AM
Default Re: Steering Column...WTF!? (crv-techu)
i'm way past that. you're missing the point. both bolts are OUT and i'm trying to line up the column to the rack to bolt it down. its almost impossible at this point because its shifted and you can only get one arm down there to try and line it up. you can get to it if you pull the motor but i'm not doing that just to do something that should only take 10 minutes. i'm also thinking about pulling the intake manifold off...
Old Apr 26, 2008 | 09:04 AM
blkb18's Avatar
Couldnt you unbolt the lower yoke (inside car right before it goes out the firewall). I would think that would alow you to move it around to line up your bolts. Good luck.
Old Apr 26, 2008 | 10:58 AM
Default Re: Steering Column...WTF!? (blkb18)
figured it out today and got it bolted up. now i remember how to do it. there's a trick to it. now i can help anyone else out that might have the same problem in the future.
Old Apr 27, 2008 | 03:55 AM
Dogginator's Avatar
Daisy... Daisy...
Care to make a write-up?
Bense
26
Oct 31, 2016 09:15 PM
Luckywhiteboi
Feb 28, 2009 10:24 PM
tree fingers
Feb 12, 2008 10:56 AM
cbstudd77
Nov 28, 2006 03:34 PM
Booger's_Rex
Nov 3, 2002 12:53 PM
