Starting issue
Old May 20, 2014 | 07:03 PM
z7rix's Avatar
Default Starting issue
I picked up my 94 teggy a few weeks ago and everything was good until last week two mornings in a row it had rough starts. Then friday night i was out and it wouldnt crank, but it would push to start. So I went and bought a new starter and still nothing so i took the starter to advanced auto parts and they tested the starter and it was good so i had them test my old one and that one was good too.. but today i tried putting jumper cables on the positive side of my battery and connected the the other side the the flat power side of the starter and it starts right up every time. So the starter is good, but where does the flat cable come from? What needs to be replaced. The starter just isnt getting any power to crank. And my battery is good. Any advice??
Old May 21, 2014 | 10:03 AM
tamboo's Avatar
10 Year Member
Default Re: Starting issue
tried cleaning your grounds?
Old May 21, 2014 | 05:20 PM
fcm's Avatar
fcm
Old Fart
If it starts with a bypass jump, [ I am assuming that is what OP means, "and connected the the other side the the flat power side of the starter and it starts"] grounding is not the issue.
https://honda-tech.com/forums/tech-misc-15/simple-diy-start-circuit-test-%5Bbypass-jump%5D-2961164/
Do the above tests and let me know what you find. 94
Old May 22, 2014 | 09:13 AM
silvertaxasteg's Avatar
I am SO fancy!
Troubleshooting for gen 3 integra starting issues. Requires a multimeter.
Seems to be a lot of 'no start' issues on Tegs lately.
File Type: txt
Old May 22, 2014 | 04:37 PM
fcm's Avatar
fcm
Old Fart
You do not need a multimeter, a simple 12V test light, [not LED type] is all you need.94
Old May 23, 2014 | 04:48 AM
I am SO fancy!
Agreed. Either way will work, but when someone's not too familiar with electrical work, disconnecting the battery (as in my little write-up - it's easy to miss with the huge pictures I can't resize) removes the chance of shorting something out.
Personally, I don't have a test light. Might be worth it for those one or two times I couldn't watch the DMM display for whatever reason.
azandford
Apr 29, 2010 06:03 AM
alkoholikwun
Nov 23, 2009 01:03 AM
JDMB20TDA
Oct 2, 2008 08:38 PM
Integra_drk
Dec 27, 2006 10:19 AM
OPTION2ek V.2
Jul 18, 2005 10:05 PM
