Starting engine without timing adjustment...?
Old Dec 8, 2005 | 05:51 PM
P@@RB@Y's Avatar
Default Starting engine without timing adjustment...?
I just put on a new distributor and I dont have a timing light gun at the moment.Is it safe to start the car?
Also when the old dist. was on I just mark a line from the middle of the dist. and ran it to where it bolts up to the head.If I get the new dist. pretty much even with that mark will the timing be pretty much set?
Thanks
Old Dec 8, 2005 | 06:08 PM
P@@RB@Y's Avatar
Default Re: Starting engine without timing adjustment...? (P@@RB@Y)
Bump
Old Dec 8, 2005 | 06:15 PM
KeithsDAteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P@@RB@Y &raquo;</TD></TR><TR><TD CLASS="quote">...If I get the new dist. pretty much even with that mark will the timing be pretty much set?
Thanks</TD></TR></TABLE>
Yes It should be in the same time as the original starter.
Old Dec 8, 2005 | 06:34 PM
bigwhitebucket's Avatar
Default Re: Starting engine without timing adjustment...? (KeithsDAteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeithsDAteg &raquo;</TD></TR><TR><TD CLASS="quote">
Yes It should be in the same time as the original starter.</TD></TR></TABLE>
What???You cookin??
You have to start it eventually to time it. Just try to set it right in the middle and start it up. You can get it pretty damn close by ear, then limp it straight to a mech. to time it.
type-GGSR
Dec 26, 2007 09:52 AM
Dunc
Jan 7, 2005 01:09 PM
tianporn
Aug 1, 2004 12:20 AM
hYpE-R-29
Dec 8, 2003 07:26 AM
b20ek
Jul 6, 2003 08:04 PM
