Start up problem
Old Nov 10, 2005 | 09:11 AM
AzntstyleZ's Avatar
Default Start up problem
wsup all, A while ago I had an accident with the teg, the front left section of the car is pretty much fucked, mainly the knuckle assembly. I began repairs on the car and everything seems back to normal. Stupid of me I forgot to unplug the battery, maybe because i didn't know how long the repairs would take. So after replacing my battery my car does not start. It's been idle for about a month now, it still cranks and it also lets out gas because i can smell it but no spark. So I'm assuming its one of four reasons: 1. Sparkplugs 2. Sparkplug wire 3. Distributer cap and rotor 4. Ignition coil... I know honda's are notorious for having sensitive distributors and ignition coils so my assumption would be that the problem is there, but I just wanted to double check with everyone before i started buying parts for the car.. what do you guys think? Thanks in advance.
Old Nov 10, 2005 | 10:30 AM
BlackDAy's Avatar
Default Re: Start up problem (AzntstyleZ)
well if u replaced the battery but it's been sitting there for a month, you should charge the battery w/ an external charger or a jump start. try that first.
Old Nov 10, 2005 | 02:12 PM
AzntstyleZ's Avatar
Default Re: Start up problem (BlackDAy)
No.. the replaced battery hasn't been sitting there for more than 2 days.. the battery is disconnected as well.. so the battery is still 100% good.
Old Nov 10, 2005 | 10:47 PM
AzntstyleZ's Avatar
tttt
bopbop93030
Jan 11, 2012 09:56 AM
samvilay
May 11, 2010 04:36 PM
theelemental
Dec 3, 2008 08:08 AM
Surubasi00
Dec 8, 2005 06:53 AM
