Spittng oil!!!
Old 03-26-2008, 09:16 AM
cm8719500's Avatar
Default Spittng oil!!!
I've been having this problem with my 00 GSR, It spits oil though the exhaust and it idles like crap...........
DOes any one know what might be causing it???
Thanks guys
Old 03-26-2008, 01:16 PM
dwamp2006's Avatar
Default Re: Spittng oil!!! (cm8719500)
valves seals?
Old 03-26-2008, 02:33 PM
mc-integra111's Avatar
Default Re: Spittng oil!!! (dwamp2006)
Yep, likely valve seals. Does it spit oil at load (cruising)? If not, then its probably the valve seals. If if gets worse with load, its probably the piston rings.
goodtrouble's Avatar
The idle could be a number of things... I know my brother had an idle on his and it was because the screws on his tb were a bit loose. But like a said... idle could be a number of things
Old 03-29-2008, 11:35 PM
man03globe's Avatar
i agree or that valve ajustment u got sukkd
Old 03-30-2008, 12:09 AM
thanh4o8's Avatar
Default Re: Spittng oil!!! (man03globe)
get a leak down its most likely ur valve seals
drumminforev
09-11-2006 02:16 PM
Layziebtnh055
11
04-21-2004 03:24 PM
jdm169
03-02-2003 06:11 PM
FAST94GSR
12-15-2001 05:07 PM
Quick Reply: Spittng oil!!!
