speedometer problems... I need help fast
Old Jun 3, 2007 | 08:24 AM
DC2 Mang's Avatar
Default speedometer problems... I need help fast
my speedometer has been acting strange, jumping up and down the past 2 weeks, then last night it just crapped out
I have cleaned the grounds on the car, cleaned the pins on the sensor itself and got a new speed sensor and works perfectly fine
my car is a 95 obd1 gsr, 96 spec itr swap, odb1 wire harness with the obd2 alternator clip spliced and soldered on, odb2 stock itr ecu with an obd2a to obd1 conversion harness and a 98 spec cluster with the stock green film on the back
I am hoping someone has had the same problem as me before or can supply a wiring diagram for the speedometer and sensor
thank you much in advance
Old Jun 3, 2007 | 12:50 PM
DC2 Mang's Avatar
Default Re: speedometer problems... I need help fast (DC2 Mang)
97DGreenEx
Oct 9, 2006 08:49 PM
ahemming06
Mar 27, 2006 12:13 PM
lostsol530
Jan 6, 2005 07:25 PM
AllMoToRB18c
Sep 15, 2004 08:32 AM
DR. ON POINT
Nov 7, 2001 01:40 PM
