speed sensor and vtec problem
Old Mar 20, 2008 | 02:35 PM
dc2much's Avatar
Default speed sensor and vtec problem
ok first off i have a 94 teg rs with a gsr swap with a s300. last week my speed sensor code went up after i replaced my distributor. so i replaced it and i still didnt work. so i had a small brush that is supposed to be used in the kitchen and i cleaned it the best that i could. so i started driving and it worked. since i finally got my running right i went out and got on it to see if how it felt. i threw it in second and hit the gas and felt the vtec and then felt it go out. and now my speedometer don't work again. is there anyway or anything to use to clean the connection. or do i have to replace the clip. also before my vss went out when i got on it, it didnt really feel like there was vtec until i got it up to 7400 rpms then it hit hard. the reason i replaced it was because my icm went out and all of a sudden i couldnt go past 7000 in 1st or 2nd and in third gear i was able to but it slowed down alot.
Old Mar 21, 2008 | 10:39 AM
dc2much's Avatar
Default Re: speed sensor and vtec problem (dc2much)
anybody have imput?
stehigs321
15
Mar 1, 2019 05:16 PM
JDM_SOHC
Nov 8, 2005 08:20 AM
jaydm ferio
Dec 6, 2004 08:08 PM
Typiko512
Jun 12, 2003 01:06 PM
NZ Vtec Weapon
Nov 29, 2002 08:27 PM
