What does this mean?
Old 04-04-2009, 08:33 PM
FRKWOO's Avatar
Default What does this mean?
so i was driving to the honda-tech meet today and on the freeway during rush hour and it was clutch gas brake for about an hour heading there and on the way home my clutch pedal felt like its softer and wasnt as stiff to press down anymore? does it mean the clutch is going out?
Old 04-04-2009, 08:36 PM
Former User's Avatar
Default Re: What does this mean?
Is the fluid low in the clutch master cylinder? If so, check for a leak at the top of the clutch pedal, the master cylinder, and the slave cylinder. If you can't find a leak, bleed the hydraulic system and check the clutch fork where it contacts the slave cylinder.
Old 04-04-2009, 08:38 PM
FRKWOO's Avatar
ill check thanks but its doesnt have anything to do with the clutch right now?
Old 04-04-2009, 08:43 PM
It's probably not the clutch itself.
Old 04-04-2009, 08:44 PM
FRKWOO's Avatar
ok thanks ill check the fluids
Old 04-04-2009, 09:37 PM
gamby's Avatar
Leaky/worn-out slave cylinder is probably the culprit (as prev mentioned).
Mine was losing fluid. It broke in half when I removed it from the car--pretty far gone.
Fairly easy to swap out--just be sure to bleed the air out of the cylinder before you bleed the lines.
Part was around $120, IIRC. Fluid is Dot 3 brake fluid IIRC.
Old 04-04-2009, 10:34 PM
toner297's Avatar
we have a winrar
Old 04-04-2009, 10:45 PM
i8yourpinkcrayon's Avatar
I'd recommend reading this
https://honda-tech.com/forums/showthread.php?t=2407755
Old 04-05-2009, 03:58 AM
Resident Gearhead
BryanM.'s Avatar
That's seems more like the price for the clutch master cylinder, not the slave cylinder. Most auto parts store sell the slave cylinders for $20-$30.
jlowellintegra
11-27-2010 08:15 PM
patrick4588
08-31-2008 05:58 PM
eg6sittingon57cs
08-08-2007 10:44 AM
ScootinIntegra
04-27-2004 10:57 AM
myhatchrips
12-05-2003 07:21 AM
Quick Reply: What does this mean?
