smog failed second time
Old Sep 30, 2003 | 06:07 PM
GSRacer1's Avatar
Default smog failed second time
first i went to smog the bitch i got these numbers
at 15 mph
hc 113 max allowed were 61
co 0.51 max " " 0.54
nox 2072 max allowed 467
at 25mph
hc 29 max 45
co 0.49 max 0.53
nox 966 max 754
second time --
OK, I changed the cat with a new carsound cat and put in some of that denaturized alcohol, put the timing back 2 degrees, got new plugs
and
you know what, I hate california's smog laws
I passed the nox part with flying colors but
hc and co2 levels went sky high
new numbers are
15mph test
GAS- MAX - MEASURED
HC - 61 - 170
CO - 0.54 - 2.44
NO - 467 - 43
25MPH TEST
HC - 45 134
CO - .53 1.85
NO - 754 32
PLEASE HELP
can i figure this out with out breaking bank
Old Sep 30, 2003 | 06:10 PM
hndarcrb18c1's Avatar
Default Re: smog failed second time (GSRacer1)
Please post your mods!!!!
Old Sep 30, 2003 | 06:11 PM
n0 iNTegRiTY's Avatar
lol. That seems like a truly royal pain in the ***
I can't really think of anything other than dustin off the stock cat again (that is, if you still have it) and slappin it on for the test then puttin her back in the storage bin for the next emissions test
Good luck
Old Sep 30, 2003 | 06:12 PM
GSRacer1's Avatar
Default Re: smog failed second time (hndarcrb18c1)
cold air intake, exhaust, carsound cat, denso iridium plugs and nology wires thats it
Old Sep 30, 2003 | 06:39 PM
GSRacer1's Avatar
i need some answers people
Old Sep 30, 2003 | 07:42 PM
hadboosttroy's Avatar
well put the stock plugs and wires on, its just a thought. i mean if you can't smog a intake and exhaust then thats just f'ing crazy. Any CEL's?
Old Sep 30, 2003 | 07:49 PM
xx dc2teg xx's Avatar
check your crankcase ventilation
tegasaurus's Avatar
Default Re: smog failed second time (hadboosttroy)
your car isn't chipped, is it?
Old Sep 30, 2003 | 09:55 PM
kimo98GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRacer1 &raquo;</TD></TR><TR><TD CLASS="quote">cold air intake, exhaust, carsound cat, denso iridium plugs and nology wires thats it </TD></TR></TABLE>
I just had my car smogged in Cali and had no problems with the following mods. Apex N1 catback exhaust, Cold Air Intake (AEM), MSD Ignition (Box, Coil, Tach Adaptor), MSD Wires, Skunk 2 Cam Gears (adjusted 2 degrees), Denso Irdium Spark Plugs, Power Pulleys (AEM), DC Sport Header (4-1), Stock Cat...I would say put the stock cat back on the car....
Old Sep 30, 2003 | 10:31 PM
WundedSaint's Avatar
From the first data it looks like your car is going into a lean misfire, on the second set of data it looks like you're running to rich. The o2 sensor maybe biased lean, fuel filter might be clogged up or your fuel pump is starting to die. As long as you have your aftermarket parts set at "stock" factory setttings it should pass. Recheck your timing, are you sure you know you're setting it correctly?
Old Sep 30, 2003 | 11:39 PM
Frito1's Avatar
I failed twice because when I switched my cat out I accidentally pulled the wires out of the harness that runs to the o2 sensor. Follow the wires from the 02 sensor and check to see if they got pulled, but then again, you would throw a code if they were yanked out. Good Luck, and yes California has some bullshit smog laws.
Old Sep 30, 2003 | 11:50 PM
six_speed's Avatar
1st off, what did you do before the smog test? ie..woke up in the morning..then went there?
well when the car starts...the cat is not very efficient at doing its job..so the high level of (hc) hydro carbon can be expected. A suggestion is to drive the car really hard..for like 5-10 mins..getting the car's temp to normal operating temp. The vtec is calling for ya. This time it's business..lol
i dont know anything about what's causing your co2 level to be so high. Maybe suggesion above will cure that too.
Good Luck.
May i add vtec help me pass smog, so i think it might help you. Your mods shouldn't be the prob. It could be ur engine misfiring that account for the high hc count.
Modified by Humping_dragon at 1:16 AM 10/1/2003
Old Oct 3, 2003 | 11:16 AM
integrx's Avatar
New User
go to kargen and buy some of the pour in pass smog stuff.
Old Oct 3, 2003 | 12:18 PM
Xumarius's Avatar
Default Re: smog failed second time (integrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrx &raquo;</TD></TR><TR><TD CLASS="quote">go to kargen and buy some of the pour in pass smog stuff.</TD></TR></TABLE>
Or you can get a Denatured alcohol. This is what you do:
1. Go to Home depot or any hardware store that sells Denatured Alcohol quart or gallon. (Good for a cheap Fuel injection cleaning also)
2. Wait until you are at half of a quater tank the day you go to the testing station.
3. 10 minutes before you to the test pour the Alcohol in your tank and then go take the test.
4. Once you do your car should be burning extremely clean and you should pass with flying colors.
5. after the test go top off your tank with the gas of your choice.
6. You car should will drive really well and you'll be flying down the raod with your passed test!
Old trick people used to do in FL before they got rid of the Emmisions and inspection laws down here....
Old Oct 3, 2003 | 03:35 PM
phuckinilltegie's Avatar
Default Re: smog failed second time (Xumarius)
do the denatured alcohol trick, i did this and it worked. i had my gas down to like two marks before empty. also change your oil and spark plugs. my car passed really easy after all that and im in cali. make sure you have stock timing
Old Oct 8, 2003 | 09:40 AM
Cheap Bastard's Avatar
New User
I got my 99 Si to pass. JUN3 cams, ITR intake manifold, OBDII ecu, 2.5"carsound cat.
Fresh oil, filter, fresh stock range plugs, cam gear set to 0, retard timing as far as possible, and lean the fuel out.
good luck
Old Oct 9, 2003 | 10:40 AM
roadrunner's Avatar
You definitely seem to be running too rich now, so try advancing your timing those 2 degrees you took out.
Please try to give us as much info as you can. You stated that you pulled 2 degrees but 2 degrees from what? How many miles on the engine? It's like walking into the doctor's office and saying, "It hurts..." and expecting him/her to fix you up without knowing where, when, how, etc...
La Zona Imagery
May 23, 2016 11:05 PM
b18c1vtecdc2
Nov 6, 2009 07:18 PM
Blackhtch
46
Dec 30, 2004 12:02 AM
GSRacer1
Oct 1, 2003 01:23 PM
SimbaDogg
Jul 2, 2003 09:17 AM
