simple intake question
Old Apr 13, 2003 | 08:07 PM
jonoknut's Avatar
Default simple intake question
ok ive had my short ram intake on for about 6 months, it came with a metal bracket, as well as my brothers and some friends, and for some reason we could never figure out where it goes. its an L shaped bracket with holes in it. i always assumed it was to hold it up, btu none of us ever used it. Anyways, the intake burned a hole in my a/c line and that sux *** but thats a different story. so when i get it fixed, to prevent it from happending again, where does that bracket go? pictures would be nice if you have them. BTW its a 95 gs-r. thanks
jon
Old Apr 13, 2003 | 08:35 PM
xteg95's Avatar
Default Re: simple intake question (jonoknut)
I think mine ended up in the garbage somewhere
Old Apr 13, 2003 | 08:56 PM
tilt's Avatar
I'd like to know as well... couldnt find a place to mount the bracket. bump
Old Apr 13, 2003 | 09:01 PM
VTECorona's Avatar
Default Re: simple intake question (tilt)
Mine came with a metal bracket with a twist in the middle of it. No clue where to install or what its purpose is. AEM CAI
Old Apr 13, 2003 | 09:17 PM
DOHC_VTEC's Avatar
Default Re: simple intake question (97RedTegGSR)
i didn't really know what it was for either but it looked like it is supposed to help support the big filter at the end of the intake. so i bent the bracket a little and bolted it so it would help support the filter.
Old Apr 14, 2003 | 01:24 AM
tC_Dragon's Avatar
Default Re: simple intake question (DOHC_VTEC)
not sure where the bracket goes.. but for those with the aem cai on GSR's let me give u a word of warning.... Be carefull where the piping contacts the AC lines, cuz it will rub thru the foam and eventually create a leak in the ac pipe which means money! freon's not all that cheap and neither is stupid factory only ac lines. My roomates gsr is showing similar wear n tear on the ac lines so in order to protect it we cut some radiator hosing n ziptied it around the ac lines... the thick *** rubber on it should help some.. but we will periodically inspect the thing so no biggie.
Old Apr 14, 2003 | 04:30 PM
VTECorona's Avatar
Default Re: simple intake question (pdcdragon)
yeah, that happened to a friend of mine that bought a no-name brand cai that had no mounting bracket. rubbed right through his AC line and costed him 700 to replace it.
Old Apr 14, 2003 | 05:31 PM
jonoknut's Avatar
yes, dam that ac line, mine has a big hole in it, im gona try to have someone weld it up and try to save some money.
Old Apr 14, 2003 | 05:48 PM
tC_Dragon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97RedTegGSR &raquo;</TD></TR><TR><TD CLASS="quote">yeah, that happened to a friend of mine that bought a no-name brand cai that had no mounting bracket. rubbed right through his AC line and costed him 700 to replace it.</TD></TR></TABLE>
damn 700??? dats a grip of cash!!!
Old Apr 14, 2003 | 07:04 PM
riceball777's Avatar
i never used mine
i threw it away and i never had a problem with my intake
Old Apr 14, 2003 | 08:45 PM
jonoknut's Avatar
Default Re: simple intake question (riceball777)
alright so no one knows what the piece is?? kinda unusual they would be in all the kits, but no one knows what the hell it is.. . .
Old Apr 14, 2003 | 08:51 PM
jabroni95gsr's Avatar
Same happened to me, but it wasn't a no-name intake, it was an iceman, that i was running shorty for a few years...anyway, a quick trip to the junkyard and $50 later for the AC lines i needed and about 3hrs of work and i replaced it. Then i just got some zipties and made sure it can't rub anymore so it won't happen again!
Tong.Y
10
Aug 31, 2010 01:52 PM
honda_coupe
12
Aug 14, 2007 10:09 PM
SiCiViC2000
Mar 14, 2006 12:23 PM
Beave0101
Jul 13, 2003 07:11 PM
