Side markers question
Old Aug 22, 2004 | 02:12 PM
Dc2 Powered's Avatar
Default Side markers question
ok so i have seen that some sidemarkers have 3 wires and some have 2..
how many would i need to do this..
i kinda want the sidemarkers like the corner lights.. when u turn the light on once when only the corners are on the sidemarkers are on, also would like them to blink as i signal..
Old Aug 22, 2004 | 02:51 PM
c'mon someone knows!!
Old Aug 22, 2004 | 03:16 PM
MAV3RiCK478's Avatar
Default Re: (Dc2 Powered)
well the DA's have 2 wires and how they light up is basically however you wire them. if you want them to light up when your corners are on then splice them into those corner wires. if you want them to just blink splice them into the bumper lights or the corner wires that just blink. hth
Old Aug 22, 2004 | 03:20 PM
i own a dc2 they work the same like that?
Old Aug 22, 2004 | 03:27 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If you want them to function as the 94-97 corner wedge bulb does, just tap 2 wires into those. If you want them only to signal (proper operation) then tap 2 wires into the turn signal and ground wires of the larger bumper light bulb.
Old Aug 22, 2004 | 04:47 PM
The-LS's Avatar
Default Re: Side markers question (Dc2 Powered)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc2 Powered &raquo;</TD></TR><TR><TD CLASS="quote">ok so i have seen that some sidemarkers have 3 wires and some have 2..
i kinda want the sidemarkers like the corner lights.. when u turn the light on once when only the corners are on the sidemarkers are on, also would like them to blink as i signal.. </TD></TR></TABLE>
you want to tap BOTH leads of the sidemarker bulb into BOTH 12V+ of the parking light and signal 12V+ leads. You do not hook up any grounds trying to do what you want. I know it may sounds weird, hooking up 2 12V+ wires into a bulb and no ground. But thats the easiest and cleanest way to do what you want.
Old Aug 22, 2004 | 05:50 PM
Community Builder
Default Re: Side markers question (Black-LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-LS &raquo;</TD></TR><TR><TD CLASS="quote">
you want to tap BOTH leads of the sidemarker bulb into BOTH 12V+ of the parking light and signal 12V+ leads. You do not hook up any grounds trying to do what you want. I know it may sounds weird, hooking up 2 12V+ wires into a bulb and no ground. But thats the easiest and cleanest way to do what you want. </TD></TR></TABLE>
If the application is a 94-97 Integra, you can just tap the 2 wedge bulb wires in the bumper light, since that bulb operates as described above.
In case you're wondering, the bulb is grounded by passing through the larger 1157 bulb's positive wire, going through the filament, and then out the 1157's negative wire. When the 1157 turn signal comes on, the current to the wedge bulb is interrupted, and makes it go off.
iHOPEyouCHOKE
Mar 17, 2006 06:55 AM
thatHEMIguy
Jan 10, 2006 02:56 PM
kim_2_da_chee
Jun 23, 2005 09:32 AM
Jonnyr4c
14
May 5, 2005 06:36 AM
lowlude92
Jan 15, 2003 05:09 AM
