shocks
Old Mar 27, 2006 | 06:16 AM
a2dadamm's Avatar
Default shocks
hey guys wassup... listen im wondering how hard it is to change front shocks/struts on a 90 teg..is it worth doin ur self or having it done also if the car being lowerd has any affect...any adice or tips thanks
Old Mar 27, 2006 | 06:23 AM
Lan's Avatar
Lan
Default Re: shocks (a2dadamm)
Easy man DIY! Your first time will probably take you an hour or 2.
Old Mar 27, 2006 | 07:14 AM
purplegsr's Avatar
Default Re: shocks (Lan)
Very very easy, especially if the car is already lowered. The hardest part on a stock car is removing the springs (usually people just rent a spring compressor or are really careful when they decompress the spring).
Here is a how-to, as long as you have a metric socket set with ratchet and a breaker bar, jack, and jackstands, you should be good to go. Remember to reuse your stock tophats, bumpstops and washers, and remove the brakeline brackets and put them on your new shocks.
http://www.c-speedracing.com/h...r.php
Old Mar 27, 2006 | 08:03 AM
a2dadamm's Avatar
Default Re: shocks (purplegsr)
cool sounds good so do i need a spring compressor or should it just slide out the car has a set a coil overs on there and i havent had to much exp. with suspension work but i like to try everything..
Old Mar 27, 2006 | 08:06 AM
purplegsr's Avatar
if it already has coilovers, you won't have a problem. The springs are shorter than stock, so they aren't compressed enough to hurt anyone when you pop off the top bolt. Just don't pinch your fingers or anything, since you will be holding the shock piston in place with an allen wrench and turning the bolt with a closed end wrench.
Old Mar 27, 2006 | 08:11 AM
PnoyJeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a2dadamm &raquo;</TD></TR><TR><TD CLASS="quote">cool sounds good so do i need a spring compressor or should it just slide out the car has a set a coil overs on there and i havent had to much exp. with suspension work but i like to try everything..</TD></TR></TABLE>
u dont really need a spring compressor, it just kind of makes the job a little easier and safer.
a guy at a local shop doesnt use one..when he takes off the springs he puts the shock in front of a tire, steps on the shock, n takes of the top with his airtool n just lets the spring shoot at the tire. it really works well cus thats how he always does it, n it makes the job a lot faster. he used a compressor for putting the springs on the shocks but only for 2 of them cus they gave him a hard time
Tim2179
Suspension & Brakes
Sep 4, 2010 08:44 PM
CRISIS
Suspension & Brakes
Jun 11, 2006 08:47 PM
97LXAcc0rd
Aug 30, 2005 01:30 PM
TexTeg
Apr 6, 2002 04:20 PM
d0nkeyxPunch
15
Jan 14, 2002 10:01 AM
