Shifter movement
Old May 27, 2004 | 03:30 PM
yellowbuffalo's Avatar
Default Shifter movement
I brought my car in for a 30k maintenence. Anyway the car feels like its dragging itself to me, but anyway my main concern is shifter movement. I have 32k on my car and when Im cruising I notice my shifter move when i accelerate and decelerate. I told acura about the problem and they said everything is fine.
Old May 27, 2004 | 03:34 PM
NelsitoTeg's Avatar
Default Re: Shifter movement (yellowbuffalo)
It should move a little. Mine does the same thing. It just moves a lil right. Nothing dramatic?
Old May 27, 2004 | 03:38 PM
Default Re: Shifter movement (NelsitoTeg)
its very noticable and annoying.
Old May 27, 2004 | 03:41 PM
SuzukaBlueAP2's Avatar
What do you mean you "see" the shifter moving when you accelerate?
Sounds to me that what you are describing isn't just the shifter moving, but the whole linkage assembly moving when getting on an off the gas due to slack in the rear engine/tranny mount.
Old May 27, 2004 | 06:01 PM
Bay_707's Avatar
mine does this slightly... before and after shift linkage was replaced.
Old May 28, 2004 | 09:41 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Such is life in a car with a solid shift linkage. The engine moves when load is applied, and since the shifter is rigidly mounted to the transmission, it's going to move also.
Cable shifters, on the other hand, should not move while driving. If they do, that means synchro problems (ask me how I know).
Old May 28, 2004 | 10:29 AM
Default Re: Shifter movement (PatrickGSR94)
You're right Patrick...
That movement can be minimized with poly bushings. Not only for the shifter, but the engine.tranny mounts as well.
WeakSauceEJ8
Sep 15, 2011 03:38 PM
Hatchman98
Mar 20, 2007 10:51 AM
dr_latino999
22
Jan 15, 2007 04:14 AM
starbury
Feb 15, 2005 09:58 AM
Sketch_hs
21
Mar 31, 2004 12:51 PM
