shifter bushing install--help
Old Apr 7, 2002 | 01:50 PM
GruvyTune's Avatar
New User
Default shifter bushing install--help
I found one answer in a search but I can't seem to get this new Energy Suspension bushing in no matter how hard I try. I used a screw driver to try and force it in at an angle and everything just keeps slipping out!
Any ideas?
Old Apr 7, 2002 | 01:58 PM
Padronis's Avatar
Default Re: shifter bushing install--help (GruvyTune)
I think I just put the bushing on the ground, put "the bar" on top and stepped on it.
Old Apr 7, 2002 | 02:04 PM
ingrate's Avatar
25 Year Member
Default Re: shifter bushing install--help (G2LSS)
grease it up and SQUEEZE as hard as you can
Old Apr 7, 2002 | 02:42 PM
GruvyTune's Avatar
New User
Default Re: shifter bushing install--help (In7egrity)
You must have hands like a vice grip to do that with all that grease on the thing making it slip around.
I like the idea of stepping on it do do it. That may work. Does the entire bar just fall out? I don't want to take out my whole exhaust to remove it. I have a 3" thermal so there is not alot of room to drop it. There are 2 bars there. Does the shift stabilizer bar come out alone and disconnect from the shifter bar? I didn't take a good enough look under there.
Old Apr 7, 2002 | 03:35 PM
kkim's Avatar
here. read through on how to install ashort shifter. they show how to drop the shift linkage w/o taking the exhaust off.
http://www.hondaracing.ca/installs/shifter/index.htm
good luck!
jacoop86
10
May 23, 2006 11:53 AM
EM199dcs
16
May 18, 2006 11:09 PM
awps
Sep 9, 2005 07:25 PM
hondasport2000
Sep 3, 2003 01:10 PM
95GS-Racin
Dec 24, 2002 06:44 PM
