Shift Problem
Old May 1, 2002 | 12:02 AM
grngsr01's Avatar
Default Shift Problem
Has this happened to anyone else???
When shifting from 2 - 3, there seems to be a bump as it goes into 3rd. No grinding sound is being made, just a bump.
Is this normal
car has 19k on it
Old May 1, 2002 | 05:22 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Shift Problem (grngsr01)
what do you mean by a bump? Does it feel like the car hits a bump? Or is it something you feel in the shifter? clarify please
Old May 1, 2002 | 06:23 AM
Ohlias's Avatar
Default Re: Shift Problem (PatrickGSR94)
I think I know what you mean. I'm having the same issue with my car going into first from a dead stop. However, it's very sporadic. I ust seems like a little notch is blocking you from getting into gear right? All I do is rerelease and depress the clutch one more time... It sucks though, makes the person in back of you think you can't drive....
Ohlias
Old May 1, 2002 | 06:34 AM
Regular Series's Avatar
Honda shifters are kinda "notchy-feeling" (if that's what you mean). Also, if this is your first car that uses a direct mechanical linkage to the gearbox....you're going to feel a lot more feedback than with cable actuated shifters. HTH...?
EL2
May 14, 2018 07:31 PM
juston
May 22, 2010 12:34 PM
trooper0641
14
May 14, 2010 12:31 AM
ej193
14
Mar 3, 2009 01:42 PM
96_h23
May 2, 2008 11:58 AM
