Shift Knobs..
Old Jan 25, 2003 | 10:14 PM
CWESTINAP1's Avatar
Default Shift *****..
I have the stock itr shift **** but i do not have the bolt that keeps it aligned underneathe the shift ****. my brother switched shift ***** and misplaced that bolt. anyone know where i can get this bolt? i was thinking of getting a new **** maybe, can u guys post pix of your ***** and rate them? thanks
Old Jan 25, 2003 | 10:32 PM
Nameless RB26's Avatar
Default Re: Shift *****.. (CWESTINDC2)
You don't need that bolt to keep it aligned...
Get a piece of something (I used an eraser) and put it in the end of the shift **** hole, then tighten it untill it's aligned right.
Old Jan 25, 2003 | 10:45 PM
zer0zer0 TypeR's Avatar
the "nut" from acura costs under $2.00. just go pick one up.
Old Jan 25, 2003 | 10:48 PM
CWESTINAP1's Avatar
Default Re: Shift *****.. (zer0zer0 TypeR)
whats that nut called? i called acura and they weren't sure. and yes i do need that bolt cuz when i put the **** on, the **** turns too much or not enough, and the gear #'s aren't straight.
Old Jan 25, 2003 | 10:51 PM
it's not called anything, just call the parts department, tell them you own a (year) Type R, than tell them i need the reverse locking nut that goes under the shift ****. THAN, if the parts guy is competant, he'll look up the diagram on the computer and find the part number. it's really quite simple, call again and ask for the reverse locking nut, they should know easily what you're talking about
Old Jan 25, 2003 | 10:54 PM
Junior_r's Avatar
part # 90310-ST7-Z00
Old Jan 25, 2003 | 11:08 PM
CWESTINAP1's Avatar
Default Re: Shift *****.. (Junior R)
hey thanks guys, and thanks junior r for the part #.
Old Jan 26, 2003 | 01:01 AM
kHoA DoGG's Avatar
Man, I had the same problem. But in my case, I just found a nut lying in the garage and used that. Then went to OSH to get my friend one. Only cost 3 cents and some gas.
Old Jan 26, 2003 | 01:44 AM
NunRacer's Avatar
I had the black leather with red stitching **** and replaced it with a JDM titanium shift **** and the difference was night and day. It gave a more direct feeling to the car
Old Jan 26, 2003 | 09:30 AM
98cwitr's Avatar
i went to the honda dealership and bought a nut that goes on a s2000...looks and fits great
Old Jan 26, 2003 | 11:27 AM
CWESTINAP1's Avatar
thanks for the help guys
Old Jan 26, 2003 | 11:46 AM
Junior_r's Avatar
The S2000 and ITR use the same nut, same part #
Old Jan 26, 2003 | 08:11 PM
CWESTINAP1's Avatar
thats some more good advice. now i can goto either acura or honda =D thanks guys
Old Jan 26, 2003 | 08:31 PM
Alaskan98ITR406's Avatar
New User
I just got the Black Spoon Sports shift ****. It seems a little too light, ut I have yet to put it on my car and try it out because my R is not running.
Old Jan 26, 2003 | 10:25 PM
B2FiNiTY's Avatar
Default Re: Shift *****.. (Alaskan98ITR406)
Spoon duracon is very light since it's plastic. You will feel more vibrations from your car but it does not get hot at all.
Old Jan 27, 2003 | 02:00 AM
SoCal ITR's Avatar
Default Re: Shift *****.. (B2FiNiTY)
I reccomend Miata shift *****; they are great and I won't be upset if someone takes it!
Old Jan 27, 2003 | 02:14 AM
01CWITR's Avatar
damn mine is silver one damn cold in the winter time especially in the morning and in summer it's hot
Old Jun 17, 2010 | 07:29 PM
98r860's Avatar
Thanks for the info for the nut that goes underneath the JDM shift ****. Acura part # 90310-ST7-Z00. The forums are great!
Hackura
Nov 29, 2014 10:45 PM
pfcle
Honda Civic (2006 - 2015)
May 17, 2007 08:55 PM
mattdenali
Aug 17, 2005 09:05 PM
daich
Aug 7, 2004 10:56 PM
done
Oct 10, 2002 06:24 AM
