shaking.
Old Oct 24, 2007 | 02:44 PM
clean3two3's Avatar
Default shaking.
alright i was driving my car one day and scratched the bottom off my car before i jumped it off some bump and broke a radiator hose.but after that something in my engine shakes when idling and moving?any suggestion
Old Oct 24, 2007 | 02:59 PM
Padawan's Avatar
Darth ModerVader
Default Re: shaking. (clean3two3)
Maybe you broke an engine mount?
You aren't really giving much information to work with.
Old Oct 24, 2007 | 03:15 PM
g0tgot's Avatar
check rear motor mount...
Old Oct 24, 2007 | 10:45 PM
clean3two3's Avatar
ok more info it shakes my whole front but it seems to be coming from the passengers side and it makes my exhaust rattle too also makes a squeaky noise but i hear it coming from my side but at the bottom of the engine.streets of los angeles blow one more thing it also makes my shifter shake to.one of my friends told me that my transmission could have gotten out of place
Old Oct 24, 2007 | 11:51 PM
gsrob's Avatar
Default Re: (clean3two3)
Sounds like it may be your driving, not just the streets of Los Angeles. Why would you jump you integra anyway?
Old Oct 25, 2007 | 12:35 PM
clean3two3's Avatar
oh i let the car roll down in neutral this was in the night my lights arent that bright but when i seen the bump i hit the brakes but i still hit and jumped it.and i didnt do it on purpose you swear i did it on purpose its my 1st car and im trying to fix it up and take care of it
Old Oct 25, 2007 | 12:50 PM
GSRBrent's Avatar
ok cut him a break, i sugest pop youer hood start your car have you and a friend handy, pull your e-brake up and put it in first let it out of first carrfully then a little harder, this is were your friend comes in, he will be watchin to see if theres any serios shifting in the mounts, or he might be able to spot a problem, you can also look at your mounts by eye and see if there worn, if not mounts seek further advice hope i helped
Old Oct 25, 2007 | 11:22 PM
clean3two3's Avatar
im thinking of taking it to the mechanic to see what he says because he gots a car lifter thing but imma ask him if he can check it then to see how much would it cost me.i kinda noticed it made my pedals stiffer when shifting
Old Oct 31, 2007 | 01:25 PM
clean3two3's Avatar
i found the problem a bracket from the radiator mount has no bolts on it.the mounts are just sitting their rattling around
maxogsr
Jun 13, 2007 03:00 PM
93egsir
Jun 7, 2007 12:51 PM
Cyber ITR
Jan 2, 2004 02:02 AM
JoeyBallzSI
Oct 10, 2003 08:24 AM
330R
Sep 9, 2002 07:58 PM
