Shakey engine/chassis?
Old Nov 13, 2004 | 01:26 PM
noob with an RS's Avatar
Default Shakey engine/chassis?
My stock 94 RS B18B1 has 190000 miles on it. I know thats a lot but the car is in a REAL GOOD running condition.. it runs smooth and doesnt sound crappy. But when i am on the freeway and start hitting 80+ MPH the car seems a little shaky.. not very shaky but shaky enough to notice a difference.. the steering wheel doesnt jerk or anything like that.. it just scares me because I immediately assume that the shakiness indicates that my car is being driven too hard or something.. i don't know. I know i can't expect a super smooth ride at 80 MPH... or can I? is it shaking because my engine is putting out so much work and shouldn't be or is it the frame of my car bouncing or whatever from the speed? Is it just a poor stock suspension system? i just had it aligned last month when i purchased it because it use to veer off to the left.. Any input on any relevance to this subject will be greatly appreciated.
Old Nov 13, 2004 | 01:31 PM
Elemental's Avatar
maybe check your motor mounts and the tighntess of the bolts on your suspension.
Old Nov 13, 2004 | 01:33 PM
s2kkid's Avatar
By your description, it doesnt sound like the motor is any issue.
You said you had your car alligned because it veered off. How are those tires up front?
are they worn unevenly to one side? cupped(high and low spots?) etc.
Inspect them really good.
When was the last time you had these tires balanced and rotated?
Are you experienceing this vibration upon brakeing? etc
Old Nov 13, 2004 | 01:36 PM
AlxSiR7's Avatar
Default Re: Shakey engine/chassis? (noob with an RS)
wheel weight could have fallen off..
Old Nov 14, 2004 | 01:32 PM
vinai's Avatar
My vc boots ase shot and ha high speeds the wheel has as lot more pull on it @ high speeds and kicks every once and a while. I know that is my problem cuz I just had and aligmnet and balance and everything else is good
Old Nov 14, 2004 | 10:03 PM
vinai's Avatar
Default Re: Shakey engine/chassis? (vinai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinai &raquo;</TD></TR><TR><TD CLASS="quote">My vc boots ase shot and ha high speeds the wheel has as lot more pull on it @ high speeds and kicks every once and a while. I know that is my problem cuz I just had and aligmnet and balance and everything else is good</TD></TR></TABLE>
Aww crap i can't even spell type correctly My cv boots are shot and at The more i read it i realy suck
Vtec04
Jul 9, 2017 11:56 AM
JDM3STAGEVTEC
Apr 27, 2009 05:25 PM
turbotime
10
Sep 26, 2005 11:21 PM
pennies_hatchie
Dec 30, 2002 10:45 PM
