Safe Way to Replace Ignition Rotor
Old Aug 30, 2004 | 04:20 AM
Sanj's Avatar
Default Safe Way to Replace Ignition Rotor
I replaced the ignition rotor on my friends car and had to bump the starter to get access to the screw to replace the ignition rotor. After replacement the car did not start. I had to install a new coil. Any tips on how this could have been
prevented.
Thank you
Sanj
Old Aug 30, 2004 | 06:28 AM
Xsi's Avatar
Xsi
I don't see how changing the rotor could have broken the coil, maybe it just went bad?
Old Aug 30, 2004 | 07:48 AM
4U2NV's Avatar
Default Re: Safe Way to Replace Ignition Rotor (Sanj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sanj &raquo;</TD></TR><TR><TD CLASS="quote">I replaced the ignition rotor on my friends car and had to bump the starter to get access to the screw to replace the ignition rotor. After replacement the car did not start. I had to install a new coil. Any tips on how this could have been
prevented.
Thank you
Sanj</TD></TR></TABLE>
That's fine... My screw wasn't lined up when I replaced my rotor, and my friend and I just turn the motor over a couple of times till it was lined up... Everything went fine...
Old Aug 30, 2004 | 09:49 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Safe Way to Replace Ignition Rotor (4U2NV)
A better way is to just rotate the engine via the crankshaft pulley bolt.
Old Aug 30, 2004 | 10:00 AM
4U2NV's Avatar
Default Re: Safe Way to Replace Ignition Rotor (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">A better way is to just rotate the engine via the crankshaft pulley bolt.</TD></TR></TABLE>
True good point.... I'll try that next time...
mightyjoecivic
11
Jul 13, 2022 08:04 PM
Darkniss
Aug 23, 2017 09:43 AM
clewis3
Mar 23, 2010 11:49 PM
ApexiChild
Mar 18, 2004 05:45 AM
