Safe To Boost?
im not talking about the cheap kit with cheap turbo and wastegate its turbonetics t3 and evolution wastegate. you can sell both and upgrade to precision and tial. integra boy you know where you can go and what you can do. punk ***!
this is the ebay listing item number 4567791441
$1,629.95 + 90 shipping
NEW Intercooler Turbo Kit b-series Honda/Acura This kit only uses top quality parts at a very affordable price. Everything is brand new never used. Why spend $2,900? Build your own kit and save! Add up to 150HP with this kit!
Brand New Garret/Turbonetics T-3 Turbocharger, polished to a mirror shine
This turbo is designed to be a perfect match to the DOHC honda motors which promotes fast spool up and top end power. Very little turbo lag with turbo. Turbo has an exhaust A/R of .48 and a 60 trim T3 compressor. Turbo is good for 340 Hp. Hybrid upgrades are available. Turbonetics hybrid turbos available for upgrade $299 extra.
B series turbo header
Quality polished tubular style manifold made of 304 stainless steel
Will fit all Honda B series engines
You can keep power stearing and AC pump.
Treadstone bar and plate front mount intercooler
2.5" Inlet/Outlet - High Flow!
Over 30% more efficient then other designs. Highest quality intercooler anywhere!
Core size 22" by 6" by 3.5"
Supports up to 500HP efficiently!
Turbonetics 35mm Evolution Wastegate
Will support more horsepower then you could throw at it!
Maximum accuracy (one spring included). Boost controllers available in our other auctions!
Comes with extra flange for dump tube, 2 gaskets and all necesarry hardware.
Mandrel bent 304 stainless steel intercooler and turbo pipes
Includes silicone couplings with clamps, nitril reducer and elbows
These charge pipes are stainless steel and will never rust or corrode like steel and aluminum, and are easily brushed or polished for a show quality look. Used by all the top racers!
Turbo intake Filter
Oil supply and drain kit
3'-3AN stainless steel oil supply
1'-5/8" high temp oil return
includes all necessary hardware & fittings
Stage 2 Blow off Valve
Extremely loud blow of valve. Features a 1.25" stainless steel weld on adapter.
Steel downpipe
Steel downpipe kit (Weld to fit ANY setup), Includes mandrel bent piping!
External Wastegate Block-off Flange (may vary from picture)
Turbo intake Filter
Steel downpipe
I wouldnt buy anything off of Ebay. I have had some friends buy supposedly good stuff...and end up getting ripped off. Either piece together your own kit, or go with Full-Race.
RuthlessEF-9
Dec 3, 2002 08:51 PM
