IS THIS SAFE?
Old Apr 10, 2007 | 09:10 AM
94lspower's Avatar
Default IS THIS SAFE?
I was wondering if it is okay to spray wd-40 o n the alternator,pw steering and crank belts, because someone told me that u shouldnt do i. Something around that area is squeaking real bad, and i have no clue what it is, thanks
Old Apr 10, 2007 | 09:15 AM
be.twenty's Avatar
i'm assuming wd40 will eventually dry out the belts and therefore not good to spray there...
Th3savinday's Avatar
Default Re: IS THIS SAFE? (94lspower)
ive heard people using it also and havent heard anything really bad, but you never know, it is pretty flamable stuff...that got spray just for belts at your local auto store, might even be cheaper
Old Apr 10, 2007 | 09:18 AM
VTEC_PRODUCTION's Avatar
Default Re: IS THIS SAFE? (Th3savinday)
the squeaking is inside your alternator...you may have to change it soon my friend...other than that there is belt spray just for belts as previously stated...its one of those thing you will need to eventually replace...
Old Apr 10, 2007 | 09:22 AM
frontwheelfanatic's Avatar
if you want a temporary solution to your belts, any auto store sells a product called "belt dressing"
why would you use wd-40 anyway? wd-40 is a lubricant, belt noise is caused by the belts not getting 'traction' on the pullies, wd-40 would probably just make it worse. think of it this way- would you wet the road to drive with your bald tires???
Old Apr 10, 2007 | 09:37 AM
94lspower's Avatar
Default Re: IS THIS SAFE? (frontwheelfanatic)
what ampage should i get, or does it really matter, i have a 94 ls
Old Apr 10, 2007 | 09:50 AM
94lspower's Avatar
Also, does anybody know a link that shows u how to remove and install an alternator, thanks
Old Apr 10, 2007 | 10:14 AM
be.twenty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94lspower &raquo;</TD></TR><TR><TD CLASS="quote">what ampage should i get, or does it really matter, i have a 94 ls</TD></TR></TABLE>
ampage?
look into finding a helms.. it will guide you step by step on overhaul
Old Apr 10, 2007 | 10:38 AM
bseries_ben's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frontwheelfanatic &raquo;</TD></TR><TR><TD CLASS="quote">think of it this way- would you wet the road to drive with your bald tires??? </TD></TR></TABLE>
umm... yes?
Old Apr 10, 2007 | 10:55 AM
integdriver4's Avatar
amperage will probably be fine, the problem enlys in the bearings if indeed it is your alternator that is squeaking. if when you rev the engine the squealing goes away than you have a loose belt (if you didn't already know that), the second step i would take is to go ahead and buy a new alternator, and be sure to keep the reciept. remove the belt from the alternator and spin it. remove from the box the new alternator that you just bought, and spin that. if you feel a difference and its rough or if feels like the bearings are loose than proceed to replace the alternator. if it feels smooth than continue to check the power steering pump, and a/c compressor. good luck.
Old Apr 10, 2007 | 11:36 AM
kinick313's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frontwheelfanatic &raquo;</TD></TR><TR><TD CLASS="quote">if you want a temporary solution to your belts, any auto store sells a product called "belt dressing"
why would you use wd-40 anyway? wd-40 is a lubricant, belt noise is caused by the belts not getting 'traction' on the pullies, wd-40 would probably just make it worse. think of it this way- would you wet the road to drive with your bald tires??? </TD></TR></TABLE>
good analogy haha
Old Apr 10, 2007 | 12:09 PM
94lspower's Avatar
Default Re: IS THIS SAFE? (kinick313)
the squeaking doesnt go away when u rev it, but yea thanks
Old Apr 10, 2007 | 01:26 PM
SilverDc2's Avatar
put baby powder on the belts, just a little bit, usually goes away.
BB1 H22A LUDE
Jun 17, 2007 04:36 PM
return_2020
Dec 5, 2004 06:05 AM
grlstockb18c1
Feb 6, 2004 10:45 PM
hobo79
Feb 22, 2002 03:40 PM
