Main Relay or something else
Ok here we go. Car ran fine. Was parked for a few months and now will not start again. Tested all of the wiring from the relay to the different locations ECU, injectors, fuel pump, etc... All of the connects were going to the main relay. Tried 3 different relays and all are doing the same thing. CEL and oil light stays on. Relays are not clicking. The under hood fuse box makes a clicking sound but unsure if there is anything that would prevent it from powering up. If I even remember correctly the main relay is getting power. Any idears or suggestions would be appreciated. Pme more thing the GND on the relay where does that ground to?? I'm starting to really wonder if that may be the problem and the cure
Modified by zCivic at 8:25 AM 12/13/2005
Re: Main Relay or something else (zCivic)
well it was something else. One of the black yellow wires in the underhood fuse box wasn't going to the main realy. Jumped it and the relay is now powering the fuel pump, ECU and IACV
98typerar
14
01-25-2014 03:34 PM
