S3 flashing, and speedometer not working
Old Sep 5, 2006 | 11:56 PM
special915's Avatar
Default S3 flashing, and speedometer not working
I have a 1993, auto, 1.8 L 1993 integra. I had a problem once in a while that the s3 light would flash and it would turn over but would not start, and if you let it sit for about a couple of minutes it would be fine. But now the car turns on but the s3 flash's the guages will not work in odometer, speeodomter, and so forth. ANd then the check engine light comes on after a while. Just started happening.
I saw a similar question pop up yesterday on these forums, but now i don't see it. Wondering what the problem is, cause tranny seems to be grrrreat, and everything about it runs smooth.
Old Sep 6, 2006 | 05:07 AM
crx_88_si's Avatar
you need to check the ecu trouble codes (which is why the check engine light comes on).
btw.. what is S3 ?
Old Feb 8, 2020 | 02:55 PM
Kevin D Albert's Avatar
Default Re: S3 flashing, and speedometer not working
hey brother did you ever figure out the problem because I'm having the same problem I'm trying to figure out what it is
Old Feb 8, 2020 | 07:16 PM
wunfstgsr's Avatar
Loved
Community Favorite
Try making your first thread and not bump a old one. We will chime in and help, no point in bumping a old thread the OP has obviously moved on from the issue.
marinersfaninmd
Acura TSX
Jun 15, 2009 07:24 PM
Eg_hatch_95
Mar 15, 2009 10:35 PM
91b16acrx
Apr 20, 2008 09:20 AM
2000si
May 9, 2005 01:16 PM
RAB
Mar 9, 2003 10:00 PM
