mil-spec harness, distributor????
Old Dec 13, 2010 | 01:14 PM
95turbotypeR's Avatar
Default mil-spec harness, distributor????
Ok i posted something like this a little while back. this is a little more specific. I just finished my mil-spec harness, and now my car wont start. I did not use any special wire for the distributor wires, the ones that were shielded i left inside the car, and i just extended the wires on the outside of the car(engine bay side). as soon as i turn the key on i get a solid check engine light, and the care will not start. if you have any information as to why, and what to do to fix the problem please let me know. anyone else have the same issues???? if it is as simple as using shielded wire for the distributor i will do that i just dont want to tear the harness apart more than once. pleas any help would be appreciated. Thanks again in advance!!!!!
Old Dec 13, 2010 | 01:59 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Default Re: mil-spec harness, distributor????
first of all, props on making your own harness. they're eyeball-gougingly pull your hair outicly easy. if you've done one, you know... you know all too well lol.
so ok, is it possible that any of the shielding is contacting your leads? solid cel... does it turn over at all? I've ran unshielded wire on distribuor leads before, it missed a LOT, especially under load. It wasn't the smartest thing to do, but it did start up reliably. I managed to get to work that week on it while I waited for some more shielded stuff to come in the mail.
visually inspect your connections as well as you can, check that all of your colors match up on both ends, with some diagrams and a multimeter with a continuity toner on it. I would think that the solid cel is with your connections, rather than the distributor leads being left unshielded; the car wold at least REALLY want to start or start briefly.
Good luck; and Godspeed.
Old Dec 13, 2010 | 02:20 PM
lol yeah this the second one i made thought the same thing so i redid it again and this is the same problem it had before. I know the car runs i actually used this harness b4 i cut it up to make sure it ran. however. i did not have access to a wire crimper, so i asked my brother inlaw who works with these connectors every day, to crimp the 55 ends to 6" pieces of 22awg wire. then i would just solder my ends to them. could that be the problem?? i will just cut the heat shrinking back and check all connectors i guess, you u r thinking i might have a shor somewhere in the harness???? I did heatshrink every place that i soldered. Yeah i thought it would be as simple as cutting the wire and pin the connector boy was i wrong!!!!!!!
Old Dec 14, 2010 | 04:56 AM
does your main relay under the dash click? does your fuel pump prime? and does your starter turn over? is there any way you can post pics of your setup?
Old Dec 14, 2010 | 05:09 AM
Everything works properly except spark and fuel. Fuel press. Is good. I will post some pics when I get home
Old Dec 14, 2010 | 12:44 PM
heres the pictures. and got an update. i checked all the gounds and the only thing that is not grounded is the green and white main sensor wire, not sure why that is not grounded, but time to quadruple check connections. enjoy the pics.
Old Dec 14, 2010 | 02:32 PM
B18c1turboedEK's Avatar
Check the that the ecu is getting power and ground...The shielded wires wont stop the car from starting, it might make it run like crap tough, since you will be getting interfance in the ecu now.
Old Dec 14, 2010 | 02:52 PM
HondaPartsHero's Avatar
Technical Hero
you need to check your firing order too, its off
Old Dec 15, 2010 | 05:58 PM
LOL thanks hero someone was just throwing the wires on dist. for pics reasons. the car is runing now and runs great. thanks for all the help everyone.
robbizza
Nov 29, 2006 04:01 PM
hondakevin21
Apr 21, 2006 11:32 PM
cjwarren4dcivic
Mar 20, 2006 02:09 PM
MoogieBoogie
Aug 5, 2005 06:30 PM
vxnine
Jul 25, 2005 05:49 PM
