Rumbling noise from drivers side
Old 12-08-2006, 04:18 PM
pghz_last_don's Avatar
Default Rumbling noise from drivers side
Hi all,
im new to honda-tech.. I have a 2000 ls, when i turn right you can hear a rumbling noise from the drivers side tire. Could it be a wheel bearing?
Old 12-08-2006, 04:20 PM
JDM_DC4_Fanatic's Avatar
Default Re: Rumbling noise from drivers side (pghz_last_don)
a wheel bearing will make a high pitch squeel, and is usuially there all the time while the wheel is turning. Could you better describe the "rumbling" noise?
Old 12-08-2006, 04:22 PM
Default Re: Rumbling noise from drivers side (JDM_DC4_Fanatic)
I only hear it when im turnin the wheel right. its kinda like virbrating noise, i know i need new rotors, just havent got around to changing them, could that be what im hearing?
Old 12-08-2006, 04:43 PM
it could be rotors ONLY if it makes a noise when you hit the brakes. A wheel bearing wouldent vibrate, unless its soo bad its about to fall out. My guess is ball joint. when you turn, there is extra stress put on them.
Old 12-08-2006, 07:58 PM
99Geeezer's Avatar
Rumbling or crackling while turning might indicate a bad cv joint.
avio
04-11-2010 12:40 PM
Mr.Luder
10-16-2007 03:54 PM
Baron55
04-07-2006 08:30 AM
Blastek
10-18-2004 08:34 AM
juicedricer
03-06-2003 05:39 PM
Quick Reply: Rumbling noise from drivers side
