Rubbing on this offset?
First off, I apologize if this is in the wrong forum. My question is if anyone has tried the 15X7 SM058s, or an offset of or similar to +31. Any input or advice would be appreciated. (My DA will be lowered 1.8 inches all around, if that helps)
Thanks
Modified by Moogen Powah at 6:15 PM 10/20/2004
Thanks
i can almost guarantee that will rub unless you roll the fenders. The outer edge of the wheel is going to sit over 1" farther outboard than the stock wheels. It probably won't rub as bad if you run 195/50-15 tires, but it will still probably rub some.
well yeah, that's what you do to accomodate wider wheels and/or lower offset. HeyMikeyyyy is running 15x7 Enkei wheels w/ +20 offset under the stock fenders, rolled of course, and 195/50 tires... looks sick.
Yeah, I saw his red Integra with the Enkei's.
I'm guessing mine will look similar to slammed_93_hatch's EG, who I believe has GABs with +32? Guess it's time to bust out the baseball bat!
slammed_93_eg has 4x114 suspension with a +32 offset which is for some reason completely different than having a 4x100 with a + 32 offset which is actually the perfect offset for an integra...
