ripped boot
Old Mar 23, 2011 | 01:29 PM
integrada9's Avatar
Default ripped boot
im not sure what the part is called but the boot is ripped on it im not sure if its an axle or what im new at fixing this part and want to make sure i order the right thing its connected to the drive shaft i know that much just want to order the whole piece and be done with it i know that would be best i took pics to show what the hell im talking about
http://i180.photobucket.com/albums/x...h206/001-3.jpg
http://i180.photobucket.com/albums/x...h206/002-3.jpg
Old Mar 23, 2011 | 01:36 PM
mouab18c1's Avatar
Default Re: ripped boot
Your pictures are not loading.
Old Mar 23, 2011 | 01:40 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
post the complete URL, not the abbreviated versions.
Old Mar 23, 2011 | 01:42 PM
integrada9's Avatar
fixed
Old Mar 23, 2011 | 02:12 PM
geetee74's Avatar
that looks like the boot to the rack and pinion. is it leaking power steering fluid?
Old Mar 23, 2011 | 02:20 PM
integrada9's Avatar
no there isnt any leakage of fluid i think its the boot to the outer tie rod but not sure theres also i clicking sound when going straight and turning not sure what that is??
Old Mar 23, 2011 | 02:29 PM
geetee74's Avatar
the picture is at an odd angle but it looks like that the boot to the INNER tie rod end. The clicking sound going str8 and turning could be the cv shafts (axles). When the joints are defective they will make a clicking sound
Old Mar 23, 2011 | 02:51 PM
1998GsRIntegra's Avatar
This, but not necessarily when the axle's are defective, but when they are worn out.
Old Mar 23, 2011 | 03:05 PM
integrada9's Avatar
well im replaceing the boot on the rod im thinking the noise is coming from that also sould i replace the rod or not
Old Mar 23, 2011 | 03:17 PM
Yes replace the tie rod. If it is clicking (which is possible) it was due to the boot breaking and letting all the grease go.
Old Mar 23, 2011 | 03:25 PM
integrada9's Avatar
both rods inner and outter?
Old Mar 23, 2011 | 03:34 PM
I would do both for piece of mind. Might as well since you will have it mostly appart any way. If one went bad, the other will fail sooner or later.
Old Mar 23, 2011 | 04:33 PM
integrada9's Avatar
so i got both rods on each side and the boots to replace??
should i buy the driveshaft with the outter tie rods??
Old Mar 23, 2011 | 04:43 PM
Ok, start with inner and outer tie rods. If you still hear the clicking then it is an axle.
What is the year and model of your integra. I'll give you the honda part numbers that you need.
Old Mar 23, 2011 | 05:16 PM
integrada9's Avatar
2000 integra gs 2 door
Old Mar 23, 2011 | 05:58 PM
53540-S04-013
53560-S04-013
Start with those. I'm not positive on the numbers for the inner rods, I dont want to give you bad info. Just tell the guy/girl at the parts counter that you also need inner tie rods for the left and right side. The above numbers are for left and right outer tie rods.
Old Mar 23, 2011 | 06:18 PM
integrada9's Avatar
thank u so much for ur help
do u think the inner tie rods are alright?
also are the inner tie rods the same for both sides??
Old Mar 23, 2011 | 06:45 PM
Honestly I dont want to say with out being there to look at them. It gets to a certain point where you cant really go any farther with a diagnosis over the internet.
As far as the inner tie rods being the same...honestly I'm not sure. You can ask the dealer if the part numbers are the same for the left and right side inner tie rods. Thats my advice on that.
Always happy to help. Good luck with everything. Post back when you have more questions, I'm sure most of us will try to help you out as much as we can.
Old Mar 23, 2011 | 07:11 PM
integrada9's Avatar
thanks for all ur help man im replacing the drivers side axle in the morn gonna call acura tom if i dont find if theres a difference in both side on the inner rods still researching everything and obtaining knowledge as i go not to hard of a project just a pita and it sucks to do but it happens
also another thing i was thinking about maybe something on the inside of the boot leaked causing it to break down gonna check the ps fluid in the morn to see hopefully none of the pipes on the rod broke ill find out tommorrow morning
thanks again bro
Old Mar 24, 2011 | 02:33 PM
integrada9's Avatar
i replace the dr side axle that was the cause of the noice but i forgot to call acura damn it
Old Mar 24, 2011 | 03:13 PM
I kinda figured the axle was causing the clicking.
Local
Mar 31, 2011 01:46 PM
StimpyBoy
Mar 14, 2008 03:18 AM
hueyduey
May 19, 2007 12:30 AM
idriveadelsol7
11
Sep 29, 2005 04:32 PM
